Patrick Keim Posted September 2, 2017 Report Share Posted September 2, 2017 I have a Dodge journey and when I went and got the oil change I had the oil pressure light come on and then it started dumping white smoke on me and I don't know what's wrong anything would help Dodge oil filter was loose so I titened that down need help badly Quote Link to comment Share on other sites More sharing options...
Armando G Posted September 2, 2017 Report Share Posted September 2, 2017 Need more info...continuous white smoke or just got a few seconds/minutes? White smoke from the engine compartment or exhaust? Is it also over heating? Worse case scenario, cracked block (have experience with that). Best case, something was spilled and just burning off. Quote Link to comment Share on other sites More sharing options...
ltdjourney Posted September 2, 2017 Report Share Posted September 2, 2017 Make sure there is oil in it if so check oil see if it has any foam in it also coolant see if it's down next could be blown head gasket???? i had journey after they did a oil change oil started leaking from oil filter couldn't see it from top because the broke oil filter cage had it for most of day to repair .this on a 3.6 v6 engine good luck Quote Link to comment Share on other sites More sharing options...
larryl Posted September 2, 2017 Report Share Posted September 2, 2017 Whoever changed the oil probably installed the wrong filter and over tightened it There are 2 different sizes of filter for the 3.6....good luck 2late4u and jkeaton 1 1 Quote Link to comment Share on other sites More sharing options...
Patrick Keim Posted September 3, 2017 Author Report Share Posted September 3, 2017 Oil filter was different from the one we had we had a 2011 not a 2014 Quote Link to comment Share on other sites More sharing options...
