Hello people. I have a need to connect external lights in a 2014 Journey to work as DRL, there is an option in the scanner that is possible to configure and active successfully. The setting for high or low light is ok, but I need to set up for external lamps, to use a double lamp in the blink But I do not know where to turn the wiring, since I do not have BCM's electrical wiring, does anyone have or can help with this? Thank you
My goal is  to let this dual lamp fully operational via the uconnect dashboard. This yellow/white lamp comes with 3 wires, +/- to blink yellow and + to white.
The lamp I'm using is this:
http://www.ebay.com/itm/2X-Canbus-PY27W-3757AK-60LED-Dual-Color-Switchback-LED-DRL-Turn-Signal-Light-Kit/262905762365?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
uconnect.JPG.0a2f903287644cc36ae539dd2055e4c9.JPG59b431daba2ca_duallamp.JPG.92bde777d815e8f2eef930b270b145a5.JPG
Edited by Alexandro Gontijo
