Parking brake won't "reset" (FIXED)
seanton
If you're trying to reset your (foot) parking brake but can't pull out the cable that comes from the front of the car far enough to fit in the equalizer,  you might need to a look inside the parking brake. There's a little spring that gets pushed in when the brake is depressed, allowing the reset to work. Mine had somehow got out of place. Just push it back in place with a screwdriver and you're good to go. Took me a while to figure this one out. This worked on a 2009 SXT with the foot brake.
