jmurphy1107 Posted October 19, 2017 Report Share Posted October 19, 2017 My 2011 Journey had a low brake pedal, like it would stop but the pedal could be pushed all the way to the floor. The master cylinder was changed which fixed the soft pedal, but now when the car is rolling and the brakes are pushed the ABS kicks in. So now every time the pedal is pressed with the vehicle moving the abs kicks in even when going less than 5 miles per hour. Is this something that can be fixed by me or is it a dealership fix? Thank you for your time. Quote Link to comment Share on other sites More sharing options...
2late4u Posted October 19, 2017 Report Share Posted October 19, 2017 so i assume the pads are in great shape and not wore down, make sure all your wire connections at each wheel are connected, other then that.... Quote Link to comment Share on other sites More sharing options...
jmurphy1107 Posted October 19, 2017 Author Report Share Posted October 19, 2017 (edited) Brakes and rotors are 3 days old. This problem started when I picked up the vehicle. It stops but abs kicks in every time brakes are pushed. Is there something that must be reset since the brakes were bleed? Edited October 19, 2017 by jmurphy1107 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted October 19, 2017 Official Dodge Support Report Share Posted October 19, 2017 17 minutes ago, jmurphy1107 said: My 2011 Journey had a low brake pedal, like it would stop but the pedal could be pushed all the way to the floor. The master cylinder was changed which fixed the soft pedal, but now when the car is rolling and the brakes are pushed the ABS kicks in. So now every time the pedal is pressed with the vehicle moving the abs kicks in even when going less than 5 miles per hour. Is this something that can be fixed by me or is it a dealership fix? Thank you for your time. Hi jmurphy1107, Sorry to hear about this! If you end up deciding to visit your local dealership for further diagnosis I'd be happy to offer assistance if needed. Just send us a PM with your VIN and let me know. Andrea Dodge Social Care Specialist Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 20, 2017 Report Share Posted October 20, 2017 Take it back to whoever did the work. Quote Link to comment Share on other sites More sharing options...
Steven Harshbarger Posted October 20, 2017 Report Share Posted October 20, 2017 1 hour ago, jkeaton said: Take it back to whoever did the work. This! Take it back, somethings not right. Quote Link to comment Share on other sites More sharing options...
bfurth Posted November 9, 2017 Report Share Posted November 9, 2017 They screwed up when they bled the brakes. My first guess would be they need to bleed the ABS module. Bleed brakes Computer involved procedure for ABS bleed Bleed brakes again And the shop you took it to is on the hook for all of it. They should have done that when they had that much of your brake system disassembled. 2late4u, larryl, jkeaton and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
