20journey11 Posted October 29, 2017 Report Share Posted October 29, 2017 I have my climate control set to sync. The back seat started blowing cold air out the top vents last winter. I turned the heater on the other day and now the passenger side is blowing cold air. If I turn the automatic off, the air conditioner comes on even though I have the temperature set at 83. Is this a computer issue or something else? I have a 2011 with the 8.4 screen. Anyone have any suggestions? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 29, 2017 Report Share Posted October 29, 2017 The ac compressor will cycle based on humidity conditions in the cabin. It is automatic and can’t be changed. Try disconnecting the battery for a bit to reset all the actuators. Quote Link to comment Share on other sites More sharing options...
davidlb512 Posted October 30, 2017 Report Share Posted October 30, 2017 I have a similar issue with my 2011 R/T. I have left/right controls, but don't have rear A/C controls. My right side blows cold, whether on feet, combination, dash, or defrost. It doesn't matter if it's on Sync, or not. I've tried messing around with adjusting the temp while sync is on, while sync is off, adjusting to cold with sync on, turning sync off, and adjusting each side individually, and vice-versa. I'm really hoping there's some simple "trick" to fixing this, and I don't have to replace the blend door actuator. Quote Link to comment Share on other sites More sharing options...
20journey11 Posted October 30, 2017 Author Report Share Posted October 30, 2017 On 10/29/2017 at 3:34 PM, jkeaton said: The ac compressor will cycle based on humidity conditions in the cabin. It is automatic and can’t be changed. Try disconnecting the battery for a bit to reset all the actuators. Expand I unhooked the positive side for over an hour. Same thing happening. Quote Link to comment Share on other sites More sharing options...
