Trouble with LED headlight
Hi, I want to install LED for my low beam but I ran into the same problem with every set I bought.
I tried three different 9006 bulb and they all work fine when I open them without the motor running, when I start the motor they stay on for a second and the they turn off.
I tried with a Canbus cancellor and with a load resistor and every combination possible of those but always the same problem.
Anyone has any ideas of what I could do?
Expand
was this 3 different sets of led (different brands ) or all from the same brand.......as i had no problem with my led lights.
  On 10/31/2017 at 3:30 PM, Bryman31 said:
just out of curiosity..... do yu have the oem headlight housings?  if so do you have a pic of the led's turned on?  id like to see what they look like from inside the car.....
Expand
I don't have a pic from inside the car. yes, stock housings.
Edited by jkeaton
Expand
It was 3 different sets from 3 different brand. At first I thought the set I bought was too cheap but the 9005 of this brand dim for the DRL and go full brightness for high beam. And I tried with different LED chip (Cree/Cob)
  • 1 month later...
