ivey_usmc Posted November 6, 2017 Report Share Posted November 6, 2017 What led fog lights are best for my15 journey? I bought some off ebay ( Yea I know) and they are less bright than the oem bulbs. Not sure with oem is but these led's are 1200lms each and suck! Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 6, 2017 Report Share Posted November 6, 2017 More expensive ones. You get what you pay for. Quote Link to comment Share on other sites More sharing options...
ivey_usmc Posted November 6, 2017 Author Report Share Posted November 6, 2017 so what brand and lumens would that be? Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 6, 2017 Report Share Posted November 6, 2017 i was just checking led fog light bulbs and most are rated at about 1000 or 1200 lms each they make it look higher in the bold print like 2000lm but that is divided between the 2 bulbs in the small print. so dont know if you can buy bigger lamps as i didnt see any,but also i didnt search that long. good luck ill just stick with the org ones as i dont use them anyways... jkeaton 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted November 6, 2017 Report Share Posted November 6, 2017 Try superbrightleds.com. They have higher quality bulbs jkeaton 1 Quote Link to comment Share on other sites More sharing options...
tjboston5676 Posted November 7, 2017 Report Share Posted November 7, 2017 these are a drop in assembly and will be the best you can get and wont cause any glarehttps://www.theretrofitsource.com/assemblies/led-fog-lights/dodge-morimoto-xb-led.html Bryman31 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Adam H Posted November 7, 2017 Report Share Posted November 7, 2017 The problem with higher lumen fog lights is that the beam is not as focused as say, headlights, and increased brightness can cause a lot of glare for other drivers. I bought these and use them sparingly for that reason while driving on rural roads. They have worked for over a year with no issue. https://www.amazon.com/gp/product/B00UBHDMT8/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1 jkeaton 1 Quote Link to comment Share on other sites More sharing options...
tjboston5676 Posted November 9, 2017 Report Share Posted November 9, 2017 wont have that problem with the fog light assemblies from trs Quote Link to comment Share on other sites More sharing options...
Bryman31 Posted December 10, 2017 Report Share Posted December 10, 2017 On 11/7/2017 at 1:00 AM, tjboston5676 said: these are a drop in assembly and will be the best you can get and wont cause any glarehttps://www.theretrofitsource.com/assemblies/led-fog-lights/dodge-morimoto-xb-led.html Expand im HIGHLY interested in getting these. do you have them? if so have any pics of them in/on? Quote Link to comment Share on other sites More sharing options...
2016Redline Posted December 10, 2017 Report Share Posted December 10, 2017 I have them. And I really like them a lot. Really good quality. Bryman31 1 Quote Link to comment Share on other sites More sharing options...
Bryman31 Posted December 10, 2017 Report Share Posted December 10, 2017 On 12/10/2017 at 10:22 PM, 2016Redline said: I have them. And I really like them a lot. Really good quality. Expand any pics of them installed and on? how easy was it to install them? Quote Link to comment Share on other sites More sharing options...
2016Redline Posted December 10, 2017 Report Share Posted December 10, 2017 Really easy to install. This is the best picture I have right now. Quote Link to comment Share on other sites More sharing options...
Bryman31 Posted December 11, 2017 Report Share Posted December 11, 2017 On 12/10/2017 at 11:05 PM, 2016Redline said: Really easy to install. This is the best picture I have right now. Expand thank you! i have a place i know could install them for me easily with a lil bit of a wait.......im not sure my lazy factor would all me to install them LOL. that being said HOW easy are they to install? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 11, 2017 Report Share Posted December 11, 2017 On 12/11/2017 at 12:33 AM, Bryman31 said: thank you! i have a place i know could install them for me easily with a lil bit of a wait.......im not sure my lazy factor would all me to install them LOL. that being said HOW easy are they to install? Expand Twist the old ones out, unplug, plug the new bulbs in and twist them back into the sockets. Pretty simple. I did mine by raising the front end up a bit and reaching. You need to be able to work without actually seeing what you are doing though. OhareFred and Bryman31 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 15, 2017 Report Share Posted December 15, 2017 JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets PSX24W 2504 LED Fog Light Bulbs with Projector for DRL or Fog Lights, Xenon White ($19.99) wasn't going to add led to the fog (driving lights) as it seamed like to much trouble but was ordering some stuff off amazon and to get free shipping i bought these lights.i miss the old days to get to your lights you just undid 2 screws, the lens pops off and put in new bulb and add your lens back and your done... now to reach the fog lights i popped off the inner fender cover turned the wheel in or out and then strained to get the light electrical connection to come loose remove the blue plastic clip on the electrical connection removed the old bulb installed the new bulb onto the connector then reconnected the bulb to the base. (glad i had bought some of the push pins couple of months ago to be used when the need was to arrive) to replace the old ones that didnt survive the removal process... AUTEX PartsSquare 30pcs Fender Liner Fastener Rivet Push Clips Retainer Fastener for Ford Chrysler Dodge Lincoln Jeep Plymouth $ 5.99 for 30 of them.....off amazon jkeaton 1 Quote Link to comment Share on other sites More sharing options...
tjboston5676 Posted December 16, 2017 Report Share Posted December 16, 2017 On 12/11/2017 at 1:45 PM, jkeaton said: Twist the old ones out, unplug, plug the new bulbs in and twist them back into the sockets. Pretty simple. I did mine by raising the front end up a bit and reaching. You need to be able to work without actually seeing what you are doing though. Expand i was talking about entire led assemblies not just led bulbs... i do not have them but plan on getting them soon. as far as install it shouldn't be more than taking out a few screws and swapping the assembly Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 16, 2017 Report Share Posted December 16, 2017 Oh. My bad. The whole assembly might involve removing the bumper cover. Bryman31 1 Quote Link to comment Share on other sites More sharing options...
2016Redline Posted December 16, 2017 Report Share Posted December 16, 2017 Pop off the push pins and pull the wheel well liner out. Then reach in and remove the screws on the assembly. There is nothing to it. Very simple to do. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 16, 2017 Report Share Posted December 16, 2017 On 12/16/2017 at 4:39 PM, 2016Redline said: Pop off the push pins and pull the wheel well liner out. Then reach in and remove the screws on the assembly. There is nothing to it. Very simple to do. Expand Good info. Quote Link to comment Share on other sites More sharing options...
RaviG Posted April 20, 2018 Report Share Posted April 20, 2018 Whats the longest size of led bulb that can fit in the factory housing? I'm seeing ones on Amazon that range from 2 to 2.6 inches Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 22, 2018 Report Share Posted April 22, 2018 (edited) On 4/20/2018 at 9:01 PM, RaviG said: Whats the longest size of led bulb that can fit in the factory housing? I'm seeing ones on Amazon that range from 2 to 2.6 inches Expand When I have a question such as this, I go and remove the bulb and check the depth myself. Best way to get an accurate answer. Go with the shortest bulb you can when in doubt. Edited April 22, 2018 by jkeaton OhareFred and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
