Rolfe Posted November 17, 2017 Report Share Posted November 17, 2017 (edited) Chrysler just replaced my radiator, oil cooler & heater core under warranty because of a no heat problem. Now I have great heat when I turn it to maximum on manual. When in automatic and I set it at 74 degrees I get some heat on the floor but 74 degree air out of upper vents. Outside temp 36 degrees and I can't get the inside warm enough to not need a coat on when I set it on 76 degrees. Any ideas? 2015 RT 35000 miles Edited November 17, 2017 by Rolfe add model Quote Link to comment Share on other sites More sharing options...
Steven Harshbarger Posted November 17, 2017 Report Share Posted November 17, 2017 It's either your controls or the blender door not adjusting properly. The dealer should be able to pull any error codes from the HVAC part of the computer. You could have a bad recirculation motor or a stuck blend door that isn't opening and closing properly. Could just mean you need a calibration performed by the dealer. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 17, 2017 Report Share Posted November 17, 2017 Take it baaaaaacccckkk!!!!!!!! 2late4u and larryl 1 1 Quote Link to comment Share on other sites More sharing options...
