Meshp Posted November 28, 2017 Report Share Posted November 28, 2017 Good day All, My dodge Journey intermittently gets stuck in a low gear and refuses to change into a higher one - note its an automatic trans. Also when reversing, the vehicle does not move no matter how much you accelerate. It just revs up and shudders. Did anyone else have a similar issue? and may i ask what the fix was? Help and advise would be appreciated. The workshops want an arm and leg to overhaul entire transmission. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 28, 2017 Report Share Posted November 28, 2017 (edited) Sorry to be the bearer of bad news, but if you have lost reverse and having gear sticking issues going forward, there is something internally wrong with the transmission that probably can't be diagnosed over the internet. Get it to a proper transmission repair facility and at least have them perform an inspection that should not cost an arm and a leg, then you can decide if it's worth it to repair. Edited November 28, 2017 by jkeaton 2late4u and OhareFred 1 1 Quote Link to comment Share on other sites More sharing options...
Meshp Posted November 28, 2017 Author Report Share Posted November 28, 2017 Cheers Thanks jkeaton Quote Link to comment Share on other sites More sharing options...
BrianS Posted December 1, 2017 Report Share Posted December 1, 2017 I had something similar happen to mine when it was only a few months old. Not sure about the reverse as I never tried it, but it would not shift out of low gear. Several starts, and restarts, and it started acting normally again. The end result was a bad sensor in the transmission. 43,000km and the problem hasn't returned. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
