Shawn855 Posted November 28, 2017 Report Share Posted November 28, 2017 (edited) 2016 journey - There's a clunk that happens on the front driver side when I hit a bump while turning right. Typically happens when weight is being applied to that area. Example, braking while turning right into a parking lot and hitting a bump on that (driver) side. Potentially ruling out struts and mounts since it doesn't happen when going straight, only when weight is being applied to that side. What do you guys think? Doesn't sounds like a hollow clunk from a balljoint. Doesn't sound like a wheel bearing since I'm not getting any humming while driving. Maybe a tie rod? Lower control arm? You guys would know better than me. Have an apt in the morning for the dealership but I'm still curious on your thoughts in case they can't find it/replicate the noise. Only 35k miles on it btw. Thanks Edited November 28, 2017 by Shawn855 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted November 28, 2017 Official Dodge Support Report Share Posted November 28, 2017 18 minutes ago, Shawn855 said: 2016 journey - There's a clunk that happens on the front driver side when I hit a bump while turning right. Typically happens when weight is being applied to that area. Example, braking while turning right into a parking lot and hitting a bump on that (driver) side. Potentially ruling out struts and mounts since it doesn't happen when going straight, only when weight is being applied to that side. What do you guys think? Doesn't sounds like a hollow clunk from a balljoint. Doesn't sound like a wheel bearing since I'm not getting any humming while driving. Maybe a tie rod? Lower control arm? You guys would know better than me. Have an apt in the morning for the dealership but I'm still curious on your thoughts in case they can't find it/replicate the noise. Only 35k miles on it btw. Thanks Hi Shawn855, Sorry to hear about this! If you need further assistance during your dealership appointment please don't hesitate to send us a PM with your VIN and let me know. Andrea Dodge Social Care Specialist Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 28, 2017 Report Share Posted November 28, 2017 It's been discussed endlessly and a common complaint. Usually the strut isolators. Ours were replaced under warranty due to clunking. Lasted about a year before they started clunking again. Replace crappy factory parts with the same crappy factory parts is a lesson in futility. If you search this section, it is probably the most common topic here. Quote Link to comment Share on other sites More sharing options...
larryl Posted November 28, 2017 Report Share Posted November 28, 2017 Some things about the Journey just suck....sadly Quote Link to comment Share on other sites More sharing options...
bramfrank Posted November 29, 2017 Report Share Posted November 29, 2017 (edited) Just went to my dealer for the same clunk for the second time - the first time it was on the left and they seemed not to have solved the problem. But I had the steering recall to do and gave them another chance to redeem themselves. And they did. It turns out that the left side HAD been an issue but that now it was the "link" on the right that connects the frame to the suspension which takes the lateral forces from the front suspension in turns that was loose. So both sides were loose, and the last time they only found the one (and probably ever bothered to check the other side) They told me they could 'hear it' but could find no problems, but when they put it up on the wheel alignment platform, they found the problem and then tightened the ends (and they also did an alignment while they were in there) and the vehicle is now as quiet as can be. I paid for the alignment, the link adjustment was covered under the warranty because my vehicle is just short of 3 years old. Edited November 29, 2017 by bramfrank Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted November 29, 2017 Author Report Share Posted November 29, 2017 A link that connects the frame to the suspension? Sway bar link? If I had the exact name it would help tremendously Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted November 29, 2017 Author Report Share Posted November 29, 2017 3 hours ago, jkeaton said: It's been discussed endlessly and a common complaint. Usually the strut isolators. Ours were replaced under warranty due to clunking. Lasted about a year before they started clunking again. Replace crappy factory parts with the same crappy factory parts is a lesson in futility. If you search this section, it is probably the most common topic here. Really? Can you point me in the right direction? I wasn't able to find any topics that discussed it sadly. Was it along the lines of when the weight is transferred to one side and turning, like my issue is? The more knowledge the better I can help my dealer find the issue. Thanks Quote Link to comment Share on other sites More sharing options...
bramfrank Posted November 29, 2017 Report Share Posted November 29, 2017 3 hours ago, Shawn855 said: A link that connects the frame to the suspension? Sway bar link? If I had the exact name it would help tremendously They describe it on the work order as a link . . . . just have your dealer call mine and ask the service department just what they did to fix my clunk because they don't know how to fix yours . . . . my name is obviously the same as I'm registered here under and my dealer is Boulevard Dodge Chrysler and their number is 514 748-2955 Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted November 29, 2017 Author Report Share Posted November 29, 2017 10 hours ago, bramfrank said: They describe it on the work order as a link . . . . just have your dealer call mine and ask the service department just what they did to fix my clunk because they don't know how to fix yours . . . . my name is obviously the same as I'm registered here under and my dealer is Boulevard Dodge Chrysler and their number is 514 748-2955 Thanks. My first challenge is recreating the noise to show them I'm not crazy lol Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted November 30, 2017 Report Share Posted November 30, 2017 I mentioned this at my last oil change too. It was pretty easy to re-create over a speed bump in their parking lot! They said they lubed everything up and they didn't hear the noise but when I drove away it was still there. They didn't have a loaner for me so I'm taking it back tomorrow and leaving it for a day or two until they can figure it out. Weird thing is different people say different things fixed it, so who knows. Like keaton said I asked about the strut isolators and they said they'll check, all we can do is mention what has been the solution for others or else the dealership will take their sweet time! Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted November 30, 2017 Author Report Share Posted November 30, 2017 4 hours ago, lmoore1436 said: I mentioned this at my last oil change too. It was pretty easy to re-create over a speed bump in their parking lot! They said they lubed everything up and they didn't hear the noise but when I drove away it was still there. They didn't have a loaner for me so I'm taking it back tomorrow and leaving it for a day or two until they can figure it out. Weird thing is different people say different things fixed it, so who knows. Like keaton said I asked about the strut isolators and they said they'll check, all we can do is mention what has been the solution for others or else the dealership will take their sweet time! Thanks for the update. Let me know what happens. I brought mine in yesterday and they couldn't recreate the noise, and said everything was nice and tight. No clunk whatsoever when driving straight, or to the left or to the right. It's only when I'm making a sharp right turn and hit a bump on that side. So weird... Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted November 30, 2017 Report Share Posted November 30, 2017 1 hour ago, Shawn855 said: Thanks for the update. Let me know what happens. I brought mine in yesterday and they couldn't recreate the noise, and said everything was nice and tight. No clunk whatsoever when driving straight, or to the left or to the right. It's only when I'm making a sharp right turn and hit a bump on that side. So weird... I will, just make sure you don't let them close out your service paperwork until YOU know it's gone. Otherwise they will note it as repaired, from how you described it sounds like the same as mine. It's especially noticeable if I hit a speed bump at an angle. Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted November 30, 2017 Author Report Share Posted November 30, 2017 34 minutes ago, lmoore1436 said: I will, just make sure you don't let them close out your service paperwork until YOU know it's gone. Otherwise they will note it as repaired, from how you described it sounds like the same as mine. It's especially noticeable if I hit a speed bump at an angle. Thanks will do. I'll remind them to keep it open, so that when i go past my warranty, I won't have to pay for it hopefully. Only 3000kms left of warranty. Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted December 5, 2017 Author Report Share Posted December 5, 2017 Any updates? My dealer is the king of "nothing is wrong". Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted December 5, 2017 Report Share Posted December 5, 2017 55 minutes ago, Shawn855 said: Any updates? My dealer is the king of "nothing is wrong". I'm heading over in about an hour to pick it up... They said ti was the lower control arms but I'm going to have to drive it first. Last time they said it was fixed and it made the noise as I was pulling out of the parking lot. I'll let you know if that fixed the issue. Shawn855 1 Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted December 5, 2017 Report Share Posted December 5, 2017 4 hours ago, Shawn855 said: Any updates? My dealer is the king of "nothing is wrong". Got it back and drove it around for a good 30 minutes or so. No clunk or creak going over any bumps... The lower control arm fix worked like a charm. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 5, 2017 Report Share Posted December 5, 2017 10 minutes ago, lmoore1436 said: Got it back and drove it around for a good 30 minutes or so. No clunk or creak going over any bumps... The lower control arm fix worked like a charm. Not for long...they replaced crappy parts with the same crappy parts...it will happen again. Quote Link to comment Share on other sites More sharing options...
Shawn855 Posted December 5, 2017 Author Report Share Posted December 5, 2017 32 minutes ago, lmoore1436 said: Got it back and drove it around for a good 30 minutes or so. No clunk or creak going over any bumps... The lower control arm fix worked like a charm. Was your clunking happening while going straight, or only while turning? Because mine ONLY happens if i'm making a right hand turn, while going downhill, and hitting a bump. So basically when all of the weight is shifted to the front driver side. Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted December 5, 2017 Report Share Posted December 5, 2017 14 minutes ago, Shawn855 said: Was your clunking happening while going straight, or only while turning? Because mine ONLY happens if i'm making a right hand turn, while going downhill, and hitting a bump. So basically when all of the weight is shifted to the front driver side. It was whenever the suspension was engaged... Most notably over speed bumps, or uneven surfaces on the road. There are lower control arms on the left and right so it may just be one of yours, or it could be a completely different issue. Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted December 5, 2017 Report Share Posted December 5, 2017 40 minutes ago, jkeaton said: Not for long...they replaced crappy parts with the same crappy parts...it will happen again. Dang negative Nancy! Haha let me enjoy it for a while at least! I know it will eventually come back, but they are under warranty for an extended period now so if I do need them replaced again it shouldn't be an issue. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 5, 2017 Report Share Posted December 5, 2017 2 hours ago, lmoore1436 said: Dang negative Nancy! Haha let me enjoy it for a while at least! I know it will eventually come back, but they are under warranty for an extended period now so if I do need them replaced again it shouldn't be an issue. LOL.....speaking from experience.....our clunk was due to struts. After they replaced them, no more noise....for about 10,000 more miles, then it slowly started coming back.... Quote Link to comment Share on other sites More sharing options...
