Who installed after market brakes - how they doing?
I put cross drilled rotors front & back along with ceramic pads-so far so good almost zero brake dust
3 months ago
Please let us know what Pad manufacturer you used (part #, cost, and source) as well as what year and model vehicle you have (not sure if all Journey's use the same calipers).
Raybestos pads-rotors from California off of eBay I have an 09 RT
I have a huge problem about this brakes issues , I live in Sydney Australia got a 2008 SXT model, the problem here in Sydney is that no one seems to like this vehicle as not much around driving with this kind so therefore aftermarket parts are a big headache. I checked Ebay and for some reason they don't ship overseas. I going on vacation on May 2010 in Honolulu Hawaii so just wondering if you guys know if they are selling after market ceramics brake pads over there ?
I'd try contacting Raybestos directly.
Did you have to buy the "special" caliper turn in tool for the back or did you figure a workaround?
I'm curious by what you mean when you talk about a special tool. I'm close to doing brakes on my Journey, but I haven't actually looked at them yet. It was my understaning that there are just two bolts to remove and then take a C-clamp and push the piston back into the caliper. Do you know something I don't?
Using a C-Clamp is the case for front brakes. The rear brakes always need a special tool to "screw" the piston back into the caliper.
In the case of my G6, the rear piston had deep grooves in them. I would fit a screw driver in it to use as a wedge and would turn the piston into the caliper. But I am not sure what the piston looks like on the Journey!
