Bill Adams Posted December 9, 2017 Report Share Posted December 9, 2017 (edited) The battery died. bought a new one replaced battery now the car is dead, no lights nowhere checked my work, meaning I pulled the battery back out. On the negative post I see where a fair size wire has broken it's bolt and broken off the cable end. two connectors remain, one with small black and white wires. one appears to be main ground lead here's the problem. I cant find this third wire.It's got to be dangling in there somewhere. if I knew where it comes from, that might help. Anybody know where? 2014 Dodge Journey 6 cyl thanks in advance. Edited December 9, 2017 by Bill Adams Forgot something Quote Link to comment Share on other sites More sharing options...
Bill Adams Posted December 9, 2017 Author Report Share Posted December 9, 2017 That green and red area is where it came off. There's a broken bolt in the center of it. Quote Link to comment Share on other sites More sharing options...
Bill Adams Posted December 9, 2017 Author Report Share Posted December 9, 2017 False alarm. The actual problem was a bad connection on the main ground wire going to the connector. Just needed cleaning. figured this out by connecting the battery with booster cable to the hot and ground lugs in the firewall. Everything worked like that, had to be in the cables. connected the ground lead to the battery end of the ground cable, nothing. Connected above the connector on the cable. Everything worked. Had to be that connection. I spent seversl hours hunting a wire that ddn't exist. OhareFred 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 10, 2017 Report Share Posted December 10, 2017 Glad you got it figured out. Quote Link to comment Share on other sites More sharing options...
