Cross compatibility on remote start years
I am looking for a remote start, but I want a easy simple one wire system, so I don't have to cut up the wires!
I have found a t harness that plugs between the button and the start module no other wires. But it's for a 2010 dodge journey I have a 2015 are they cross compatible?
No the product says 2010 journey is where it ends. But allot of the systems that it would use I would think would be the same? It's mainly the brain of the remote start that goes between the start button no other wires or connections, so I would assume that all the systems it interface with should be the same across the mid years 10 to 15
24 minutes ago, bramfrank said:
The 08-10 used a very different system than the 11 and onward do
The best way is probably to install the OEM kit that FCA sells.  But it requires that the dealer add the sales code which pretty much demands that they install it.
Check out the offerings from Fortin (www.fortin.ca)
Yea I was looking at the fortin https://www.amazon.com/Fortin-Stand-Alone-Add-Push-Start/dp/B00SCCX3G6/ref=sr_1_13?s=electronics&ie=UTF8&qid=1513297756&sr=1-13&keywords=remote+start+dodge+journey
But it takes wires like 2 I think which I'm good with cars and crap I used to install stereos and alarms but I don't want to mess with hard wiring stuff in this new of a vehicle
