Journeyrocks Posted December 18, 2017 Report Share Posted December 18, 2017 I have seen alot on here about the Chrysler Pentastar engine family and being 87 octain gas. Most all of my knowledge is older engine's where octain did matter and made them run better, performance, cleaner all that stuff could yall explain this new technology a little more please Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 18, 2017 Report Share Posted December 18, 2017 new engines are like older engines if it isnt tuned for prem then it isnt needed, and wont help some prem gases contain cleaners that might help kept your injectors cleaner than reg gas might, that might help if you have dirty injectors but not from the added octane but believe what you want.... Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted December 18, 2017 Report Share Posted December 18, 2017 exactly what 2late4u stated... It is tuned to run on 87 octane, but the additives in 89 and up can help keep the injectors cleaner. The difference is minimal though, as is the gas mileage increase. These engines were built to run off 87 octane, no need to pay more for 89 or above. Down the road as you put on more miles the higher octane might help, but until about 75k or more miles it won't make a difference. Quote Link to comment Share on other sites More sharing options...
Journeyrocks Posted December 18, 2017 Author Report Share Posted December 18, 2017 Thanks yea one of the biggest ones was injectors and valve build up Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 18, 2017 Report Share Posted December 18, 2017 Run a can of fuel injector cleaner in it every few thousand miles and you don't have to worry about build up. Quote Link to comment Share on other sites More sharing options...
Bryman31 Posted December 18, 2017 Report Share Posted December 18, 2017 1 hour ago, jkeaton said: Run a can of fuel injector cleaner in it every few thousand miles and you don't have to worry about build up. is there a brand of fuel injector thats more recommended over others? Quote Link to comment Share on other sites More sharing options...
larryl Posted December 18, 2017 Report Share Posted December 18, 2017 I use the Lucas bottle once a month or so Bryman31 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 18, 2017 Report Share Posted December 18, 2017 (edited) 1 hour ago, Bryman31 said: is there a brand of fuel injector thats more recommended over others? I'm a big fan of Gummout products. I use their multi system tune up every few months. Edited December 18, 2017 by jkeaton Bryman31 1 Quote Link to comment Share on other sites More sharing options...
hockey_puck Posted December 18, 2017 Report Share Posted December 18, 2017 I use premium for the cleaning properties and the fact that it does not contain ethanol. Not a fan of that. Since I drive so little (only about 10,000 km's per year) the cost difference doesn't bother me. Here, and in most places, regular and mid grade has ethanol in it. On a side note, I've had more than one small engine dealer tell me to only use premium without ethanol in small engines like snowblowers, lawnmowers, weed trimmers and blowers. Premium stores better, and personally I had nothing but trouble with a carb. on my gas weed eater, but on the dealers recommendation switched to premium and the issues disappeared. H.P. Bryman31 1 Quote Link to comment Share on other sites More sharing options...
N87 Posted December 19, 2017 Report Share Posted December 19, 2017 15 hours ago, larryl said: I use the Lucas bottle once a month or so I had been using Lucas in my Nissan Xterra for some time and could really feel the difference in throttle response and how smooth the engine worked. However, that resulted in both catalytic converter going bad, not too long after I started doing that. Can't say with 100% certainty, but also read about that happening in other automotive forums. So, use at your own risk. larryl and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
2016RT Posted September 13, 2018 Report Share Posted September 13, 2018 In the U.S. the EPA has made it law that ALL octane fuel will contain additives, as a dirty engine creates more HC. The extra money you pay for higher octane fuel is in effect a waste, and has been proven. In fact one test on a dyno and emission test showed that the 91 octane actually had more unburnt fuel as a result of all the additives and there gave worse emissions. As far as fuel additives goes I would be very careful. Actually I now use none. Having had several Dodge trucks, I used various engine cleaners and additives and the result was a plugged up EGR every time. I don't have the pics any longer but the EGR valve piston was sealed shut with black, burnt debris. jkeaton, 2late4u and OhareFred 1 1 1 Quote Link to comment Share on other sites More sharing options...
