MoparOrNoCar Posted January 11, 2018 Report Share Posted January 11, 2018 I have the 2014 journey, base model. Bought it used in 2016 with 35k miles. Now I'm at 63k. About 6 months ago, the radio screen would shut off (music would still play) and the lights in that compartment would shut off, AC buttons, light about cup holders etc. This would happen every couple weeks, and would last maybe 3 seconds. But the past month, it's started happening more. Atleast 3 times a week. Just today, it happened again, but this time my doors unlocked, radio screen shut off, and my Speedo tried dying. This time it lasted maybe half a second, as the Speedo only dropped maybe 10mph, then hopped back up. Also, about 2 months after this had started happening I accidentally shattered the screen on the radio. It still lights up and shows everything fine, just the touch screen doesn't work. Quote Link to comment Share on other sites More sharing options...
larryl Posted January 11, 2018 Report Share Posted January 11, 2018 How old is the battery? Did you try the reset by unhooking the negative cable for 10 minutes? Quote Link to comment Share on other sites More sharing options...
MoparOrNoCar Posted January 12, 2018 Author Report Share Posted January 12, 2018 Battery was replaced shortly after problems started. Also, the issues seem to happen more when im slowing the vehicle down than any other times. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 12, 2018 Report Share Posted January 12, 2018 Hope you purchased an extended warranty. Electrical gremlins can be expensive to track down. Quote Link to comment Share on other sites More sharing options...
Armando G Posted January 14, 2018 Report Share Posted January 14, 2018 Let's be honest here, electrical issues like this can not be diagnosed on a forum. You can have anything from a weak fuse to an electrical short somewhere in the system OR a corroded connection that is shorting the system out. It could be on a major current or a connection in the dashboard. You need to get it tested to narrow the issue down, and if you are so lucky, you bought the extended warranty (as stated by jkeaton). If you do want to do your own diagnostic work, start with your fuses and the ground wires. Remove the ground wires because even though they may look great, corrosion could still build up on the connection...just had a similar situation with my daughter's Ford. We got lucky, after cleaning the negative wire of the battery, everything worked fine...1 month now and no issues. Good luck. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
