hoosierdadee Posted January 18, 2018 Report Share Posted January 18, 2018 My outside temp indication is always way off the actual temperate reading of outside air. Is there an adjustment or is a sensor replacement needed? Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 19, 2018 Report Share Posted January 19, 2018 well not enough info, are you still within the 3/36 k if so take it back to the dealer,, if not i wouldn't worry about? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 19, 2018 Report Share Posted January 19, 2018 Way off compared to what? Way off high? Way off low? You could locate the sensor and then place a couple good thermometers around it to prove the sensor is off before scheduling an appt. You could also see if you can find the sensor and see if there is obsctuctions. Don't know if there is a way to adjust within the uconnect screen. ". Quote Link to comment Share on other sites More sharing options...
