Rivmaster91 Posted February 6, 2018 Report Share Posted February 6, 2018 (edited) Hello everyone, New to this forum, but not to vehicle forums in general. I am looking to change the transfer case fluid (AKA 'Power Transfer Unit fluid change') in our 2012 Dodge Journey RT AWD & apparently from what I have learned, this is one heck of a job. Easy to drain the old fluid out but a huge pain to get the new/fresh fluid back in (various parts in the way of the fill hole & very labor intensive to make room in order to get the new fluid in etc). I would like to ask members (any tech feedback would be awesome) who have done this service, if there is an easy way to complete this service without having to disassemble / remove a lot of parts in order to change the transfer case fluid or perhaps a specific tool / part one can use to make life easier? Any help with specific details would be greatly appreciated. Thank you. Edited February 6, 2018 by Rivmaster91 added content Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 6, 2018 Report Share Posted February 6, 2018 welcome to the group i have fwd so have no info on the awd someone will chime in soon Quote Link to comment Share on other sites More sharing options...
Rivmaster91 Posted February 7, 2018 Author Report Share Posted February 7, 2018 Thank you 2late Based on my research (and I am not coming into this blind so to speak) one has to take apart / disassemble quite a few items including a heat shield, among other components just to get at the fluid fill hole which is very frustrating (again, the draining is no problem...but the fill hole is completely blocked). My trusted mechanic (whom I've had for pushing 11 years now & has never hesitated performing any type of maintenance / service / repairs to my current 2012 Dodge Charger 'Blacktop' or our recently purchased 12 Journey RT AWD, and a few vehicles prior). I have no issues taking the vehicle to the dealer...that is not the issue (although I cringe at the labor charges to put less than a quart of fluid in). Am I the only one that has asked about how to change this fluid on their AWD Journey? Do my fellow AWD owners simply drive them & hope they get lucky without the PTU failing? I know there is no such thing as a 'life long fluid' in any automobile....that simply means 'the life of the warranty' Part of it is definitely how this has been engineered I suppose... Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 7, 2018 Report Share Posted February 7, 2018 have you checked with your dodge dealer for the location of the fill plug and what has to be removed or how they do it? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 7, 2018 Report Share Posted February 7, 2018 Good luck. I gladly pay the dealer for services such as this. 2late4u and OhareFred 1 1 Quote Link to comment Share on other sites More sharing options...
Carter3Journey Posted May 24, 2020 Report Share Posted May 24, 2020 Differential Assembly Fluid Change STANDARD PROCEDURE - DIFFERENTIAL ASSEMBLY FLUID CHANGE JS RDA MOUNT FILL AND DRAIN The drain plug (2) for the differential assembly is located in the bottom of the differential assembly case, toward the rear of the unit. The fill plug (3) for the differential assembly is located on the left side of the assembly case. The correct fill level is to the bottom of the fill plug hole. Be sure the vehicle is on a level surface, or is hoisted in a level manner, in order to obtain the correct fill level. Raise the vehicle on a hoist. Position a drain pan under the differential drain plug. Remove the drain plug and allow the fluid to drain into the pan. Install the drain plug and torque to 35 N·m (26 ft. lbs.). Re-position the drain pan under the differential fill plug. Remove the differential fill plug. Using a suction gun or equivalent, fill the differential assembly with 0.7 L (0.74 Quarts) of Mopar® Gear and Axle Lubricant (75W-90). Install the fill plug and torque to 35 N·m (26 ft. lbs.). jkeaton and davidlb512 1 1 Quote Link to comment Share on other sites More sharing options...
Carter3Journey Posted May 24, 2020 Report Share Posted May 24, 2020 Fluid Drain & Fill STANDARD PROCEDURE - PTU FLUID DRAIN/FILL Raise vehicle on hoist. Remove bolt (1) from lower part of PTU heat shield (2). Using a long prybar remove the retaining clip (1) from the side of the PTU heat shield (2). NOTE Position the PTU heat shield aside as necessary Remove PTU drain plug (1). Drain fluid into suitable container. Install drain plug (1) and torque to 35 N·m (26 ft. lbs.). A 10mm hex bit 7/8" long (1) and a ratcheting box angle wrench (2) will be required to remove the PTU fill plug. NOTE Position the PTU heat shield aside as necessary Using the ratcheting box angle wrench (1) and hex bit (3) remove the PTU fill plug (2). Use a gear lube pump (1) to fill PTU. (Refer to Vehicle Quick Reference/Capacities and Recommended Fluids - Specifications). Install fill plug and torque to 35 N·m (26 ft. lbs.). Reposition the PTU heat shield (2) to the side of the PTU, and install a new retaining clip (1). Reposition the PTU heat shield (2) to the bottom of the PTU, and install bolt (1). Tighten to 12 Nm (105 in. lbs.). Lower vehicle. jkeaton and davidlb512 1 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted May 24, 2020 Report Share Posted May 24, 2020 Now those are pretty detailed instructions and images.....on how to. Nice job Carter3journey ! Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 25, 2020 Report Share Posted May 25, 2020 jkeaton 1 Quote Link to comment Share on other sites More sharing options...
