HELP! 2014 Journey SE
Nrud
My journey is running hot! We changed the thermostat..flushed radiator everything was fine about 3 days then all of a sudden it runs hot...if engine is not running but car is in run mode does the cooling fan suppose to kick on when the temp reads 240-260? I’m wondering if the fan is the problem...it’s not losing antifreeze either except when it’s boiling out....
