SteveCarrollDoubleBarrel Posted March 5, 2018 Report Share Posted March 5, 2018 The door will open from the inside, but will not close unless you pull the handle from the outside to shut it. Any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
larryl Posted March 5, 2018 Report Share Posted March 5, 2018 Is there an issue with the "child lock" feature? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 5, 2018 Report Share Posted March 5, 2018 On 3/5/2018 at 12:36 AM, larryl said: Is there an issue with the "child lock" feature? Expand This. Do you have the child lock feature enabled? Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 5, 2018 Report Share Posted March 5, 2018 Child lock should not let it open from the inside. The fact that it does should eliminate it as an issue. It might be one of the rods has fallen off its position. Have to take the door panel off and look.... mechanical-idiot and jkeaton 1 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 5, 2018 Report Share Posted March 5, 2018 On 3/5/2018 at 3:37 PM, OhareFred said: Child lock should not let it open from the inside. The fact that it does should eliminate it as an issue. It might be one of the rods has fallen off its position. Have to take the door panel off and look.... Expand Thanks.....I cant read.... Quote Link to comment Share on other sites More sharing options...
mechanical-idiot Posted March 9, 2018 Report Share Posted March 9, 2018 Same thing happened to our truck at work. It was a mechanical issue inside the door. Something was not connected properly. Go to YouTube and look up how to take the door panel off. mechanical-idiot OhareFred, jkeaton and 2late4u 1 2 Quote Link to comment Share on other sites More sharing options...
