jctheo Posted March 6, 2018 Report Share Posted March 6, 2018 Hi all. I have a 2014 Dodge Journey CVP. My horn stopped working one day after blasting some moron who cut my off on the highway. Weird thing was that it only stopped working the following day. I read that dodge journey has problems with the horn spring in the steering wheel but the horn doesn't work when using the panic alarm either. I checked the fuse and it seemed ok. Is there are horn relay somewhere? I checked the box under the hood but I don't see one for the horn. Thanks! Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 7, 2018 Report Share Posted March 7, 2018 first change the fuse then if still broken i would check the actual horn by running a wire from the battery and check to see if the horn is the problem before tearing onto the steering wheel good luck... OhareFred and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
