2009 RT Posted December 5, 2009 Report Share Posted December 5, 2009 I live in a condo with many neighbours close by. Remote starting my Journey at 5:45am must piss off then off. Anyone know of a way to disable the "2 honks" feature on the OEM remote start? Thanks, 2009 RT Quote Link to comment Share on other sites More sharing options...
04redmach1 Posted December 5, 2009 Report Share Posted December 5, 2009 I can do some checking, I am also kinda iffy about it. One honk is fair I think. Quote Link to comment Share on other sites More sharing options...
hockeyman2000 Posted December 5, 2009 Report Share Posted December 5, 2009 Hey this might have something to do with personal settings in the info centre located on instrument cluster? maybe has something to do with honks on doors locking or unlocking just a thought cant check as Im at work. I have a few question about that remote too like does the vehicle need to be locked for the remote to work? also wheni do get it going through remote i unlock vehicle to get in get in put key in ignition and sometimes shuts down on me im like wtf??? anyone know what kinda range there getting with there remote? I will try to find answer for the honk thing when I get home for you if no one has gotten you a answer. Later dudes Quote Link to comment Share on other sites More sharing options...
04redmach1 Posted December 5, 2009 Report Share Posted December 5, 2009 If you even breath on the brakes first, it will kill it. You may be hitting brakes and not thinking about it. Quote Link to comment Share on other sites More sharing options...
Sam Posted December 5, 2009 Report Share Posted December 5, 2009 If you have the EVIC, go to Personal Settings (Customer Programmable Features). Turn off the horn with lock, it will also turn off the horn with the remote start. If you don't have the EVIC: Quote For vehicles not equipped with the EVIC, perform thefollowing steps: 1. Press the LOCK button on a programmed transmitter for at least four seconds, but no longer than 10 seconds. Then, press the PANIC button while still holding the LOCK button. 2. Release both buttons at the same time. 3. Test the feature while outside of the vehicle by pressing the LOCK button on the transmitter with the ignition switch in the LOCK position and the key removed. 4. Repeat these steps if you want to return this feature to its previous setting. Quote Link to comment Share on other sites More sharing options...
brwengel Posted December 6, 2009 Report Share Posted December 6, 2009 Good job Sam, I can confirm that my remote start does not chirp the horn since I disabled that feature with the remote lock. Quote Link to comment Share on other sites More sharing options...
diggit Posted December 7, 2009 Report Share Posted December 7, 2009 "I have a few question about that remote too like does the vehicle need to be locked for the remote to work?" No. When you initialize the remote starter it will automatically lock the doors anyway. "also wheni do get it going through remote i unlock vehicle to get in get in put key in ignition and sometimes shuts down on me im like wtf???" You might be touching the brake pedal as your settling into your seat or your timing is spot on. The starter will only run the vehicle for 15 minutes at a time before shutting down. "anyone know what kinda range there getting with there remote?" The other day I got to test that coming out of my work. Its about 500ft to the car and she started on the first try of the remote especially considering the rear end was facing me. I think I saw somewhere it supposed to be upto 1000 feet. Quote Link to comment Share on other sites More sharing options...
brwengel Posted December 7, 2009 Report Share Posted December 7, 2009 The only thing I can add is that sometimes when I insert the key and turn it to the ON position, sometimes I turn it too far to the Start position and this will cause the engine to shut-off. I also do not know the distance in feet that the remote will work, but it is a long way. Happy motoring... Quote Link to comment Share on other sites More sharing options...
2009 RT Posted December 8, 2009 Author Report Share Posted December 8, 2009 brwengel said: Good job Sam, I can confirm that my remote start does not chirp the horn since I disabled that feature with the remote lock. I can also confirm that my remote start does not chirp the horn since I disabled that feature with the remote lock. Thanks Sam, 2009 RT Quote Link to comment Share on other sites More sharing options...
Sam Posted December 8, 2009 Report Share Posted December 8, 2009 You're welcome! Quote Link to comment Share on other sites More sharing options...
mr.m Posted December 19, 2009 Report Share Posted December 19, 2009 i did the same (4am start). works great Quote Link to comment Share on other sites More sharing options...
