getusmonster Posted March 9, 2018 Report Share Posted March 9, 2018 I installed some led headlights tonight in my 16 DJ RT and as I installed the first one no problem checked it and it looked great. Put the drivers side in checked it looked great. Did both fogs next. Went to check looked great. So I start the car to back it off the ramps and the headlights flash 3 times and go out. Tried unplugging and replugging not working so I put old Sylvania back in and now they don't work either. Any thoughts? The parking lights still work and the fogs work no issues just no headlights at all either in led or in the original Sylvania ones. Quote Link to comment Share on other sites More sharing options...
getusmonster Posted March 9, 2018 Author Report Share Posted March 9, 2018 Well I went back out there after the car has been sitting for about 30 minutes or so and try the headlight switch again with the car off and it still didn't work until I turn the car on and the headlines came back on with the old sylvania's in them so at least that works. The LED headlights still don't work however and I'm slightly disappointed with that and that they are an $80 pair of LED headlights. Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 9, 2018 Report Share Posted March 9, 2018 well i would just return the led for a refund, installed led on my 14 no problem Quote Link to comment Share on other sites More sharing options...
HugoClement Posted March 14, 2018 Report Share Posted March 14, 2018 Hi, I had the EXACT same problem you're having and I found a pair of canbus cancellor that fixed it. They were specifically made to work with the TIPM for Dodge car. Here is the link of what I used. https://www.amazon.ca/gp/product/B072QCBQSM/ref=oh_aui_detailpage_o04_s00?ie=UTF8&th=1 Quote Link to comment Share on other sites More sharing options...
Rivmaster91 Posted March 18, 2018 Report Share Posted March 18, 2018 What specific LED bulbs did everyone use on their Journey & what site(s) did you get them from? I would like to upgrade to the LED bulbs on my 2012 RT. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted March 19, 2018 Report Share Posted March 19, 2018 On 3/18/2018 at 11:50 PM, Rivmaster91 said: What specific LED bulbs did everyone use on their Journey & what site(s) did you get them from? I would like to upgrade to the LED bulbs on my 2012 RT. Thanks in advance. Expand Sylvania has a bulb called the Zevo connect hybrid bulb that uses LED, for $99.99 they come with everything you need but it seems to be a bit more than a standard bulb change involved. I am planning on upgrading to these soon, rather than a seller on eBay or amazon (no offense to those that have, I've just had some bad experiences buying things on there). I just prefer the piece of mind (or delusion of piece of mind) buying from a larger company. Quote Link to comment Share on other sites More sharing options...
getusmonster Posted March 19, 2018 Author Report Share Posted March 19, 2018 After further review I spoke with the seller of the lights and they sent me the canbus modulators free of charge BUT, the polarity was reversed so I had to reverse the plug. That worked for about 10 minutes and then they flashed off once and came back on and then a minute or so later flashed off and never came back on. These are the ones I got. CougarMotor LED Headlight Bulbs All-in-One Conversion Kit - 9006 -7,200Lm 6000K Cool White CREE - 3 Year Warranty https://www.amazon.com/dp/B01H6NZ7BA/ref=cm_sw_r_cp_apa_6b6RAbQSQ3GTW Quote Link to comment Share on other sites More sharing options...
2016journeyrt Posted December 16, 2020 Report Share Posted December 16, 2020 I also have a 2016 rt I have tried cheap leds for 40.00 and then I spent 140 on a good set with decoders and have had same issues that you guys are having. I know this is old tread but wondering what else I can do my rt also has led taillights if that makes a difference Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 16, 2020 Report Share Posted December 16, 2020 i have bought 2 sets of led both were around $40-60 and both said Canbus Ready ready, didnt have any problems with either set the first set had one go bad after about 4 yrs then i bought the other set just got them off amazon,good luck................ 9006 LED Headlight Bulbs Mini Sized 80W 16,000LM Per Pair CanBus Ready, AUXITO 9006/HB4 Headlight LED Bulb Conversion Kit, 6500K Xenon White, Pack of 2 Sold by: AUXITO Return window closed on Feb 2, 2020 $59.99 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 17, 2020 Report Share Posted December 17, 2020 My LED's were plug and play. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
