Elmwoodie Posted March 9, 2018 Report Share Posted March 9, 2018 Hi All, Has anyone replaced their TIPM with a used/refurbished unit? (TIPM=Totally Integrated Power Management) If so, what year is your Journey, where did you get the TIPM, what issues did you have, did you require dealer assistance, did you need to reprogram, would you recommend? Any info appreciated! https://www.youtube.com/watch?v=hVBlRqlVCh8 https://www.totalintegratedpowermodule.com/ http://www.verticalvisions.com/TIPM_solutions.php https://www.dormanproducts.com/p-83320-599-926.aspx?year=2010&make=Dodge&model=Journey&parttype=Integrated%2520Control%2520Module&origin=YMM Quote Link to comment Share on other sites More sharing options...
Elmwoodie Posted March 19, 2018 Author Report Share Posted March 19, 2018 Just a note to say that I installed a rebuilt TIPM. It solved two electrical problems (door lock and front washer pump)!. The refurbished TIPM does not appear to support my backup camera though and am checking with the guys who sold it to me to see what that's about. And I have some lit dash lights and no speedometer. Hoping to get that fixed by completing a reset as per the youtube videos linked in the previous message. But I am not 100% sure how to fully disconnect the battery. In the video, its a simpler setup in a jeep. On my 2010 RT, the battery is not directly accessible and has 3 connections I can see. One negative to the negative post. Two positives, one to the TIPM and one to the accessible positive connection. I disconnect the battery negative connection up to the post. Then I disconnect the postitive connection up to the post. Then I connect the cars negative and positive connections together to drain the car. Have also tried disconnecting the positive to the TIPM, but not getting a seuccessful reset. Have only tried two hours disconnected though. I will try disconnecting a longer stretch, but am wondering if I need to disconnect the positive connection to the TIPM or not? Quote Link to comment Share on other sites More sharing options...
bfurth Posted March 19, 2018 Report Share Posted March 19, 2018 Put the vehicle on stands, remove the driver front tire, remove the wheel well cover, and disconnect the battery directly. Elmwoodie, larryl and OhareFred 1 1 1 Quote Link to comment Share on other sites More sharing options...
Elmwoodie Posted March 20, 2018 Author Report Share Posted March 20, 2018 (edited) last nite I disconnected negative from the car for about 30 minutes. Reconnected and all was well with the replacement TIPM! Backup camera, remote start, and speedometer are working again. Front washer pump and door locks working again for the first time in 18 months. ( http://www.dodgejourneyforum.com/topic/9376-power-door-locks-stopped-working%C2%A0-but-power-unlock-still-works%C2%A0/?tab=comments#comment-75707 ) Very happy with the refurbished TIPM from Mak at https://www.totalintegratedpowermodule.com/ Edited March 20, 2018 by Elmwoodie fix typo Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 21, 2018 Report Share Posted March 21, 2018 thanks for the update Quote Link to comment Share on other sites More sharing options...
