retroloko Posted March 20, 2018 Report Share Posted March 20, 2018 What's up fellow Journey owners, I just bought a 2017 Journey over the weekend & I'm already making a few adjustments. I bought LED bulbs for the interior, back up & brake lights. BUT I'm having trouble getting to the brake light bulb. I had no problem when it came to the back up light neither the turn signal light but when it comes to the brake light I'm able to twist the socket out but the actual bulb is inside the tail light, I took off the screws off the tail light assuming I would have access to the bulb by opening the tail light but no luck. Has anyone run into this problem? Thanks in advance for any help Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 20, 2018 Report Share Posted March 20, 2018 (edited) If I’m not mistaken the 2017 had led taillights and ,if so, the assembly gets replaced, not a bulb. Not sure if it’s standard or only on the upper trim levels. Edited March 20, 2018 by OhareFred jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 20, 2018 Report Share Posted March 20, 2018 If your taillights look like this, you already have LED's. OhareFred and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
