DJOverIt! Posted March 29, 2018 Report Share Posted March 29, 2018 2014 Dodge Journey we had the transmission fluid changed about a week ago it had a check engine light on and it read two permanent codes I know one was transmission line pressure low it still has the permanent codes and I believe it’s in limp/fail Safe Mode because it’s not shifting i just want out of limp/fail Safe Mode so it will shift and drive normal again is there any way I can do this on my own without going to a dealership? Also I have already unplugged the battery to try and reset the computer but that did not work unplugging the battery did not reset anything not even our preset radio stations... please help Quote Link to comment Share on other sites More sharing options...
larryl Posted March 29, 2018 Report Share Posted March 29, 2018 Who changed the fluid??? Did they use Mopar??? Did they put in the right amount???? Filter??? Yikes you are vague jkeaton and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 30, 2018 Report Share Posted March 30, 2018 (edited) Was it doing this before? You need to provide some background info. Moved to the correct section. Edited April 2, 2018 by jkeaton Quote Link to comment Share on other sites More sharing options...
lmoore1436 Posted March 30, 2018 Report Share Posted March 30, 2018 If the car is in limp mode you won't be able to fix that yourself. Take it to the dealer to get a proper diagnosis, you didn't mention how long it has been in limp mode but you should take it in as soon as possible to prevent any further damage to the transmission. jkeaton, OhareFred and mechanical-idiot 1 1 1 Quote Link to comment Share on other sites More sharing options...
