Justpassingby Posted April 19, 2018 Report Share Posted April 19, 2018 I have this problem: Start up sounds weird, The Electronic Satbility Control lamp (yellow) lits up and I can't deactivate it. (drives okay). The Electronic Throttle Control lamp lits up and I have a power loss. When you've just merged in front of a semi, those 200 feet are not enough. (Brown pants time here...). Takes an eternity to reach 50 Kph (about 30 Mph) and I have to use the manual shift to do so. Sometimes, the other ESC lamp (red) lits up. but today, it's the Check Engine that comes up, and stays on. Shutting the engine used to work (User manual reccomendations for the ETC lamp) but not any more. I have an appointment next week about some recalls and I will ask them to hook it up a diagnostic machine but I'd still like an opinion about this. I had a lot of problems with this car; breaks (four discs and calipers), Blutooth module, cruise control module, those were covered by warranty. Breaks again, rear discs and calipers (not covered...), the transmission kicks when I'm almost stopped (feels like a trailer with a bad hitch), not constant when it's time to change speeds. Doors creaks when I close them, no matter what type of grease I put on them and the climate control tends to "forget" my settings. And now, this. Depending of what the tech will tell me, this might be my last Dodge... Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 19, 2018 Report Share Posted April 19, 2018 Transmission kicks when almost stops , mine has done this since I bought it , worse when I first start out most other time it’s okay . As as for the rest it sounds like the car is going in to limp home mode . As for brakes get get away from factory parts and get good after market rotors and pads. I am done for new pads on the front of mine so I got about 30,000 miles off the front brakes . Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 19, 2018 Report Share Posted April 19, 2018 You need to get it scanned for codes in order to determine a course of action, otherwise, we are all just guessing. Parts stores will read the codes for you. Once you have the codes, post them here and we can help. All vehicles have issues. Some are more bothersome than others. Good luck with whatever you decide to do with it. Quote Link to comment Share on other sites More sharing options...
Justpassingby Posted April 26, 2018 Author Report Share Posted April 26, 2018 Update: Fresh out of the garage and it's the Throttle Body that needs to be replace. Estimate is 681.60 for parts and One hour of labour at 114.95$. The darn truck is only six years old with only 68,000 some kilometers. and with all the other stuff they found, it would cost me 3,647.46$ to fix everything. I've had cars twice that old and never had to put more than 500$ per years (including breaks and tyres). Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 26, 2018 Report Share Posted April 26, 2018 That’s a lot for a throttle body , sound like it junk yard shopping time Quote Link to comment Share on other sites More sharing options...
OhareFred Posted April 26, 2018 Report Share Posted April 26, 2018 And that’s why I buy extended warranties...... sucks but you either fix it or dump it. If you trade it in not fixed you won’t get sh1t for it. Fix what you absolutely have to and dump it. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted April 26, 2018 Report Share Posted April 26, 2018 (edited) Check out rock auto , a throttle body there is $165 or so depending which one you pick . They are very easy to replace. Edited April 26, 2018 by Dusty256 Justpassingby, 2late4u and OhareFred 2 1 Quote Link to comment Share on other sites More sharing options...
Bryman31 Posted April 27, 2018 Report Share Posted April 27, 2018 WOW throttle bodys are less than 200 usually. 4 bolts holding them in........BAM your done in less than 2 hours. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 27, 2018 Report Share Posted April 27, 2018 12 hours ago, Justpassingby said: Update: Fresh out of the garage and it's the Throttle Body that needs to be replace. Estimate is 681.60 for parts and One hour of labour at 114.95$. The darn truck is only six years old with only 68,000 some kilometers. and with all the other stuff they found, it would cost me 3,647.46$ to fix everything. I've had cars twice that old and never had to put more than 500$ per years (including breaks and tyres). Cars twice as old dont have all the computers and electronics on cars these days. You cant compare the two. I'd be looking for a used TB from a junk yard. I see you're in Canada. Too bad, I can buy a new TB from a parts store for less than $200 and install it myself. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 27, 2018 Report Share Posted April 27, 2018 (edited) i was going to say the same thing as jkeaton did, yrs ago we didnt have all these expensive parts to contend with ,just carbs and hand chokes then the auto chokes and then the dreaded automatic transmission. dam them auto makers.... Edited April 27, 2018 by 2late4u jkeaton 1 Quote Link to comment Share on other sites More sharing options...
mechanical-idiot Posted April 28, 2018 Report Share Posted April 28, 2018 Is it the throttle body or the throttle body sensor that is the problem? The sensor is on the gas pedal. You need to purchase the gas pedal (which comes complete with the sensor). 3 or 4 bolts and the sensor plugs into your wires with a small harness clip. I just got one for mine at a salvage yard for 75 bucks Canadian. You can also buy them on ebay. Any mechanic could change it for you. It's not Rocket Appliances (lol, little joke there for our members with an intelligent sense of humor). All your symptoms point to the sensor, since I had the same problem and a guy I work with just had the exact same symptoms as you had and it was the sensor. Ours is a 2012 and we got the pedal from a smashed 2013. If you check with a dealer, I think it will fit up to a 2017. Better double check that. Check a salvage yard first and save yourself some very valuable Canadian $. My dealer wanted 400 bucks for the part, but 2late4u reminded me to check a salvage yard. I am glad that he reminded me. I never even thought of the salvage yard. If you are not near a salvage yard, call one and ask them if they will ship it to you. Sometimes it is surprising how much they really do want to help you. mechanical-idiot 2late4u and jkeaton 1 1 Quote Link to comment Share on other sites More sharing options...
