Sally Posted April 28, 2018 Report Share Posted April 28, 2018 New rotors and pads but when I need to apply pressure hard on brakes there is a loud noise like the brakes are bad. Or, something else is going on. Dealer suggested pads and rotor replacement, which was done 2 months ago, now the noise is back. Anyone else have this happen? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 28, 2018 Report Share Posted April 28, 2018 (edited) Moved to the correct section. You posted in the forum help section. What kind of loud noise? Where Ian the noise coming from? Need more information. Edited April 28, 2018 by jkeaton Quote Link to comment Share on other sites More sharing options...
Sally Posted April 28, 2018 Author Report Share Posted April 28, 2018 Noise is coming from front, both sides. Yesterday a traffic light changed, I had to apply brakes, hard, there was a non metallic but loud noise that I can only describe as creaking bones, that’s not a really good description but how do I put in words what it sounded like. Maybe another trip to the dealership and take them for a ride? Quote Link to comment Share on other sites More sharing options...
OhareFred Posted April 28, 2018 Report Share Posted April 28, 2018 Who did the rotors and pads? Take it back to them and have them check it out. There could be any number of issues there. Dirt, sticking caliper, pads not sliding, etc. If you are not under warranty the dealer will charge you through the nose for brakes. Aftermarket brakes, I find, are always cheaper and usually better. I use ceramic brake pads, although a lot of people use semi-metallic. Either are fine if the job is done completely. let us know what they find! Quote Link to comment Share on other sites More sharing options...
Sally Posted April 28, 2018 Author Report Share Posted April 28, 2018 Thank you for your feedback. I will have dealer check the brakes. They installed both pads/rotors but I paid for them. Since they did the work, any follow up cost to fix should be their responsibility. I’ll post the results of what they find. Thank you again, enjoy your week-end. OhareFred and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted April 29, 2018 Report Share Posted April 29, 2018 (edited) Could also be the ABS activating if you are pressing hard enough for the vehicle to interpret it as a panic stop situation. In which case, it is normal. You are going to have to demonstrate the issue to the dealer. Edited April 29, 2018 by jkeaton mechanical-idiot and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
Sally Posted April 29, 2018 Author Report Share Posted April 29, 2018 Thank you. The dealership had suggested it might be ABS. I’ll talk with them again, hopefully we can determine what is causing this. Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted April 30, 2018 Official Dodge Support Report Share Posted April 30, 2018 On 4/29/2018 at 8:51 AM, Sally said: Thank you. The dealership had suggested it might be ABS. I’ll talk with them again, hopefully we can determine what is causing this. Hi Sally, If you are in need of additional assistance while your Journey is in service, please feel free to message us. Darlene Dodge Social Care Specialist jkeaton 1 Quote Link to comment Share on other sites More sharing options...
