dmankey1 Posted May 13, 2018 Report Share Posted May 13, 2018 Hello, I drive a 2014 AWD SXT. A few weeks ago my ESP light came on and stayed on while driving, after I turned the car off then back on, it stayed off for a while. No issue until yesterday when it started coming back on again but it seems to cycle about every 2 or 3 starts. I can't tell any difference in the car itself. I'm thinking something simple. No check engine, abs or service lights. Just the ESP light. Parts store couldn't read a code. It's due for an oil change so I'm taking it to the dealer this week but I wanted to see if anyone else has experienced this and what might I expect from the dealer. Thanks Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted May 14, 2018 Report Share Posted May 14, 2018 Electronic Stability Program (ESP) If the vehicle is equipped with ESP, once the battery is reconnected, the SteeringAngle Sensor (SAS) needs to be calibrated. The SAS requires calibration anytime the battery or an ABS (ESP) component has been disconnected for any length of time. To calibrate, perform the following: 1) Start the engine. 2) Center the steering wheel. 3) Turn the steering wheel all the way to the left until the internal stop in the steering gear is met, then turn the wheel all the way to the right until the opposite internal stop in the steering gear is met. 4) Center the steering wheel. 5) Stop the engine.Google "dodge charger ESP/BAS Light" A bunch of stuff out there -- apparently this is a know issue... with possible causes too numerous to mention. jkeaton and dmankey1 2 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted May 15, 2018 Official Dodge Support Report Share Posted May 15, 2018 On 5/13/2018 at 4:02 PM, dmankey1 said: Hello, I drive a 2014 AWD SXT. A few weeks ago my ESP light came on and stayed on while driving, after I turned the car off then back on, it stayed off for a while. No issue until yesterday when it started coming back on again but it seems to cycle about every 2 or 3 starts. I can't tell any difference in the car itself. I'm thinking something simple. No check engine, abs or service lights. Just the ESP light. Parts store couldn't read a code. It's due for an oil change so I'm taking it to the dealer this week but I wanted to see if anyone else has experienced this and what might I expect from the dealer. Thanks Hello dmankey1, We apologize for the inconvenience you're experiencing with your Dodge. Once you head back in, send us a direct message with your VIN as we'd be glad to get a case started beforehand. Jasmine Dodge Social Care Specialist jkeaton and dmankey1 2 Quote Link to comment Share on other sites More sharing options...
AyeJayy Posted May 15, 2018 Report Share Posted May 15, 2018 I was just to post about this issue as well. Mine even cuts on while in park. I will try the above method when I get off, but could you post what the dealership does as well Quote Link to comment Share on other sites More sharing options...
dmankey1 Posted May 16, 2018 Author Report Share Posted May 16, 2018 On 5/14/2018 at 11:08 AM, Dusty256 said: Electronic Stability Program (ESP) If the vehicle is equipped with ESP, once the battery is reconnected, the SteeringAngle Sensor (SAS) needs to be calibrated. The SAS requires calibration anytime the battery or an ABS (ESP) component has been disconnected for any length of time. To calibrate, perform the following: 1) Start the engine. 2) Center the steering wheel. 3) Turn the steering wheel all the way to the left until the internal stop in the steering gear is met, then turn the wheel all the way to the right until the opposite internal stop in the steering gear is met. 4) Center the steering wheel. 5) Stop the engine.Google "dodge charger ESP/BAS Light" A bunch of stuff out there -- apparently this is a know issue... with possible causes too numerous to mention. Thanks for the info! I took it into the dealer yesterday morning as it was due for an oil change anyway. They mentioned I had an outstanding recall on it which had something to do with "steering wheel wiring". Unfortunately, it sounded unrelated to my issue but might actually be connected based on what you said! Thanks again. Quote Link to comment Share on other sites More sharing options...
