jsmoritz Posted May 13, 2018 Report Share Posted May 13, 2018 So my Journey starts fine but will not exceed 2500 RPMs. It SLOOOOOOWLY accelerates and cannot exceed 40 mph. I plugged in a code reader and returned these codes: P0123, P0222, P2135, P0562 The battery was taken out and tested. In addition, we bought it in this condition so the previous owner may have messed things up by jump starting the car, etc. I read somewhere that it could be: The throttle body assembly or the PCM? needs to be reflashed Any help on anything else to try or what to try first? Thank you. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 13, 2018 Report Share Posted May 13, 2018 (edited) It’s in limp mode. Start by correcting the issues causing the codes. Edited May 13, 2018 by jkeaton OhareFred and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
bfurth Posted May 14, 2018 Report Share Posted May 14, 2018 (edited) P0562 is a low battery voltage error code, and it can happen from doing nothing more than attempting to jump start another vehicle. It is triggered when there is a 10V measurement from the battery for 60 seconds while the engine is running. All of the other error codes you're encountering are throttle pedal/body position/voltage warnings. For a 2013 - is that the original battery? If so, forget testing it, and ignore any test results with it. Just replace it. A 5 year old battery is on borrowed time as it is. As for the other three issues, it could be the throttle, it could be the throttle pedal. It could be an underlying voltage problem causing everything. Start with the battery and work your way towards the throttle body. If it is a failed throttle body, the replacement procedure is not that bad for either 2.4L or 3.6L. Procedure is disconnect battery, remove the intake resonator, remove the throttle body electrical connector, remove throttle body, clean mating surface, reinstall (this is not an exhaustive list of steps, nor is it intended to be). The 2.4L does have a computerized re-learn procedure, so you might want to look into whether or not you can do it without a scan tool (I don't know, and usually the online manual I use tells you if there is an alternative). The 3.6L does not mention any specific re-learn procedure. Edited May 14, 2018 by bfurth jkeaton 1 Quote Link to comment Share on other sites More sharing options...
ames Posted July 21, 2024 Report Share Posted July 21, 2024 Hi I both a second hand dodge journey 2011 today the owner told me the engine was good but sadly when I drove going back to my home I noticed a high RPM but low power specially on the uphill road then too much heat when I open the hood of the car I noticed also the radiator fan is not working.. maybe someone can help me to this problem thank you I'm a temporary foreign worker and I'm lay off by our company the reason I both that car is to have service to find a new employer and to attend interview in person but I think they scammed me and to be honest I kept the words he says that the engine is good that is why I both it. Quote Link to comment Share on other sites More sharing options...
