jmz1 Posted May 16, 2018 Report Share Posted May 16, 2018 I recently purchased a 2009 Journey 3.5L SXT. I replaced the starter that was bad on the car and when I turned it back on it was running rough and the check engine light came on. The code that came on was P0325 Knock sensor No 1 circuit. Can anyone point me in the right direction on where it might be located? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 16, 2018 Report Share Posted May 16, 2018 Moved to the correct section of the forum. It's under the intake manifold....good luck...This might help. https://workshop-manuals.com/dodge/journey_awd/v6-3.5l/powertrain_management/computers_and_control_systems/knock_sensor/component_information/service_and_repair/knock_sensor_removal/ mechanical-idiot 1 Quote Link to comment Share on other sites More sharing options...
mechanical-idiot Posted May 17, 2018 Report Share Posted May 17, 2018 I'm waiting for a good knock knock joke about your bad sensor. Anyone, anyone.........anyone? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 17, 2018 Report Share Posted May 17, 2018 Knock, knock.... Quote Link to comment Share on other sites More sharing options...
jmz1 Posted May 17, 2018 Author Report Share Posted May 17, 2018 Thanks and yes that helped a lot. Oh and whose there?? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 17, 2018 Report Share Posted May 17, 2018 Cargo Quote Link to comment Share on other sites More sharing options...
OhareFred Posted May 17, 2018 Report Share Posted May 17, 2018 (edited) Cargo who?? Edited May 17, 2018 by OhareFred Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 17, 2018 Report Share Posted May 17, 2018 Cargo beep beep.... Armando G and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
jmz1 Posted May 23, 2018 Author Report Share Posted May 23, 2018 Can anyone help me find where cylinder no 5 would be located on my 2009 dodge journey sxt 3.5L. It has a check engine light on and the code is P0305. The other code that is listed in P2314 and don''t know if the other code regarding the cylinder is causing it come on. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 23, 2018 Report Share Posted May 23, 2018 (edited) Google gave me this. Edited May 23, 2018 by jkeaton 2late4u 1 Quote Link to comment Share on other sites More sharing options...
jmz1 Posted May 23, 2018 Author Report Share Posted May 23, 2018 Thank you, any advice on the P2314 code? Or do you think the misfire code is causing it to come on. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 23, 2018 Report Share Posted May 23, 2018 Focus on fixing one problem at a time. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 23, 2018 Report Share Posted May 23, 2018 10 hours ago, jkeaton said: Google gave me this. its amazing what you can find out by actually using google.. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jmz1 Posted July 25, 2018 Author Report Share Posted July 25, 2018 Hello again I'm back with my 2009 journey. This time i'm lost with whats going on with it. It was working fine then the starter decided to not work anymore so I replaced it. Soon after that it started acting up with keeping the rpm staying up. When the car is in park and I press on the accelerator the rpm starts to go up but then after a few seconds it starts to slowly go down. Can anyone help with what might be wrong with it? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
larryl Posted July 25, 2018 Report Share Posted July 25, 2018 Could be your fuel pump acting up if you have no codes Quote Link to comment Share on other sites More sharing options...
jmz1 Posted July 25, 2018 Author Report Share Posted July 25, 2018 The only code stored is P0571. I looked it up and it says that's the cruise control brake switch. I don't think that'll be causing it to do that? Thanks for your response. Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 25, 2018 Report Share Posted July 25, 2018 could be an electrical gremlin with all the computers try disconnecting the battery for half hour then reconnect, might help couldn't hurt... Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 25, 2018 Report Share Posted July 25, 2018 5 hours ago, jmz1 said: Hello again I'm back with my 2009 journey. This time i'm lost with whats going on with it. It was working fine then the starter decided to not work anymore so I replaced it. Soon after that it started acting up with keeping the rpm staying up. When the car is in park and I press on the accelerator the rpm starts to go up but then after a few seconds it starts to slowly go down. Can anyone help with what might be wrong with it? Any help would be appreciated. Its supposed to so you won’t blow your engine up revving it up while in park. Armando G 1 Quote Link to comment Share on other sites More sharing options...
jmz1 Posted July 26, 2018 Author Report Share Posted July 26, 2018 Well I feel dumb now haha Quote Link to comment Share on other sites More sharing options...
Armando G Posted July 26, 2018 Report Share Posted July 26, 2018 On 7/25/2018 at 3:11 PM, jkeaton said: Its supposed to so you won’t blow your engine up revving it up while in park. Is that really it? I had no idea it had that safety feature. Quote Link to comment Share on other sites More sharing options...
jmz1 Posted July 27, 2018 Author Report Share Posted July 27, 2018 That makes two of us Quote Link to comment Share on other sites More sharing options...
rossco Posted August 14, 2018 Report Share Posted August 14, 2018 Hi jmz1, the fault code you mention relates to the brake light switch on the brake pedal. The switch usually has two circuits, one powers the brake lights and the other deactivates the cruise control if you hit the brake. It's common for half of the switch to break, I.e the brake lights still work but cruise function doesn't or vide versa. I would be changing that switch first as they are about £10. cruise control probably won't function if that broken. rossco 2late4u 1 Quote Link to comment Share on other sites More sharing options...
