ltsmitty03 Posted June 13, 2018 Report Share Posted June 13, 2018 check engine light came on my 2013 journey took it to oreillys they read it as evaporative emissions leak can you help??? Quote Link to comment Share on other sites More sharing options...
larryl Posted June 13, 2018 Report Share Posted June 13, 2018 It could be a number of things causing the light to come on as an evap emission code can be very vague to say the least especially if the car is running well. Quote Link to comment Share on other sites More sharing options...
ltsmitty03 Posted June 13, 2018 Author Report Share Posted June 13, 2018 is there anyway to get the damn light off?? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 13, 2018 Report Share Posted June 13, 2018 10 hours ago, ltsmitty03 said: is there anyway to get the damn light off?? Yes, pretty simple. Fix the problem and clear the code with a code reader. Quote Link to comment Share on other sites More sharing options...
ltsmitty03 Posted June 15, 2018 Author Report Share Posted June 15, 2018 cant afford to fix the problem thank you Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 15, 2018 Report Share Posted June 15, 2018 (edited) So what do you want from us? What is the exact code? If there is a part that needs to be replaced, you will have to buy it.....which costs money....if you can't afford to buy the part, there is nothing else to do, we can't fix it for you. Put a piece of black tape over the light so you dont have to look at it.... Edited June 15, 2018 by jkeaton 2late4u and OhareFred 1 1 Quote Link to comment Share on other sites More sharing options...
Hankster Posted June 15, 2018 Report Share Posted June 15, 2018 Could be as simple as a loose gas cap. Hank 2late4u and jkeaton 1 1 Quote Link to comment Share on other sites More sharing options...
ltsmitty03 Posted June 16, 2018 Author Report Share Posted June 16, 2018 the code is p0946 Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 16, 2018 Report Share Posted June 16, 2018 9 hours ago, ltsmitty03 said: the code is p0946 well you have the code and it called a generic code for the evap system, you can try replacing parts using the shotgun method or have a trained mechanic check it out for you, online we cant say exactly what is the problem as this is a generic code, could be a lot of things. good luck Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 17, 2018 Report Share Posted June 17, 2018 22 hours ago, ltsmitty03 said: the code is p0946 Here’s information on how to address that code. Pretty much all of them involve specialized equipment so if you can afford to take it to a shop, you’ll have to live with it unless you can do this stuff yourself. https://www.obd-codes.com/p0496 Quote Link to comment Share on other sites More sharing options...
Gemm75 Posted August 28, 2018 Report Share Posted August 28, 2018 I think Hankster hit it on the money....had a similar code come up on my 2012 journey and took it to a mechanic ..pulled a code which he cleared twice ...me thinking I had to replace the evap canister but it seemed that the gas cap was still loose making it throw a code …..I will have to mention I did fueled up prior to this happening to me...truth I was a relief it wasn't any major....I say tighten the gas cap by turning it clicking three times , run the car for a bit and see if the engine light doesn't go off then it def something else...in my opinion....process of elimination Quote Link to comment Share on other sites More sharing options...
rossco Posted August 30, 2018 Report Share Posted August 30, 2018 If the isn't gas cap isn't sealing it'll be obvious next time you fill up as there will be a lack of "hiss" noise when you open the cap. OhareFred 1 Quote Link to comment Share on other sites More sharing options...
