Bustamatic Posted June 22, 2018 Report Share Posted June 22, 2018 Need some help with a problem. Driving last night and engine starts sputtering, noticeable loss of power, my OBDII app throws a P0301 code and check engine light comes on. So today I replaced the spark plug and coil(coil was 6 years/180000 old). Take it for a drive and all seems fine, no sputtering, power seems normal, but it keeps throwing the p0301 when I drive... do i need to reset the error codes after the repair or is this a sign a another issue? Quote Link to comment Share on other sites More sharing options...
Armando G Posted June 22, 2018 Report Share Posted June 22, 2018 Usually you have to clear the code regardless of the repair being done, at least in my experience. If the code comes back after being cleared, then you will definitely know if there are other issues. Here is one method (should work on a 2012 model)... jkeaton and Bustamatic 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 22, 2018 Report Share Posted June 22, 2018 might go away after a few days of starting and stopping and if the journey is running okay,also you could run by a your local auto shop they have scanners and might be able to reset it for you.good luck and keep us informed. Gemm75 and Bustamatic 1 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 22, 2018 Report Share Posted June 22, 2018 (edited) sorry about double post site was acting up i guess...LOL Edited June 22, 2018 by 2late4u Bustamatic 1 Quote Link to comment Share on other sites More sharing options...
