olavjen Posted July 28, 2018 Report Share Posted July 28, 2018 Need Help, the windshield wipers only work in high mode, not in low, no function for the intermittent or for the rain sensor. The park position does not work either. Tried to change the motor but no change. anything I can measure , or check? Is there a wiper module? live in Norway so not too many Dodge dealer here Quote Link to comment Share on other sites More sharing options...
Armando G Posted July 29, 2018 Report Share Posted July 29, 2018 I would check the wiper relay or the switch itself. Do you have any issues with your turn signals or high beam? Not sure what you mean by the PARK position not working? You can't get the car in Park, or the light is out? jkeaton 1 Quote Link to comment Share on other sites More sharing options...
olavjen Posted July 30, 2018 Author Report Share Posted July 30, 2018 15 hours ago, Armando G said: I would check the wiper relay or the switch itself. Do you have any issues with your turn signals or high beam? Not sure what you mean by the PARK position not working? You can't get the car in Park, or the light is out? Thanks for feedback. I mean park position of the wiper motor or wipers. Now they just stop anyware. Quote Link to comment Share on other sites More sharing options...
Armando G Posted July 31, 2018 Report Share Posted July 31, 2018 Ah, got you. Then definitely check the relay, might be going bad, or you have a frayed wire somewhere (or bad connection)...either one may cause loss of power to the motor. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Kim1975 Posted February 10 Report Share Posted February 10 Where is the relay located on a 2009 mod? Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 10 Report Share Posted February 10 1 hour ago, Kim1975 said: Where is the relay located on a 2009 mod? please check out YouTube for all your info needs for videos great place ....this guy is hard to understand but he has a LOT of info on dodge journeys/fremont which are the same................. Kim1975 1 Quote Link to comment Share on other sites More sharing options...
Kim1975 Posted February 10 Report Share Posted February 10 I have seen this video, it is not the same fuse box on 2009 mod. I think the car on the video is 2011. Quote Link to comment Share on other sites More sharing options...
Kim1975 Posted February 10 Report Share Posted February 10 I think the relay looks like this: But i am not sure since i can't find it. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 11 Report Share Posted February 11 On 2/10/2024 at 8:53 AM, Kim1975 said: Where is the relay located on a 2009 mod? j 20 pink in your main fuse block under the hood,,, 30 amp,, have no idea what it looks like as I have a 2014 journey..I googled https://fuse-box.info/dodge/dodge-journey-2009-2010-fuses-and-relays Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted February 11 Report Share Posted February 11 24 minutes ago, 2late4u said: j 20 pink in your main fuse block under the hood,,, 30 amp,, have no idea what it looks like as I have a 2014 journey..I googled https://fuse-box.info/dodge/dodge-journey-2009-2010-fuses-and-relays I also have been doing GOOGLE searches and saw the same, BUT it does NOT give a location for a RELAY for wipers in the 09 model year or any of the first gen Journeys. I suspect that like the fuel pump relay, It's integral to the TIPM / fuse panel circuit board and NOT replaceable. Like many other Dodge cars of this vintage {DJ, Avenger,200, Dakota,etc.} a replacement TIPM/fuse panel is needed Kim1975 1 Quote Link to comment Share on other sites More sharing options...
Kim1975 Posted February 12 Report Share Posted February 12 TIPM Yes, i found it in the workshop manual. Quote Link to comment Share on other sites More sharing options...
