Power Steering Pump Replacement Procedure
aReLBee
Can someone please provide the procedure to remove and replace the Power Steering Pump on a 2009 Journey SXT?  It’s making a whirring sound and has already been diagnosed by Dodge as the culprit. I’m not paying them to replace it. I can do it.  Just want to make sure I do it procedurally correct.  Pictures are to show where the pump is physically located on this vehicle. I’ve seen other posts where people are removing a pump that is closer to the firewall.
  • 6 years later...
On 11/4/2024 at 2:02 PM, diymirage said:
Sounds like a fun job Karen
I havent done a powersteering pump since i put the engine for my duster together, and back then it was easy peasy
(Wouldnt surprise me if they added some wiring this time a)ound though )
Well it's day 3 I finally rented the tensioner bar to get that tensioner to let me put on the belt,  now it's squealing and it slips 1 lip of the steering pulley smh, so I read to get the pulley on with semi loose bolts and steering left to right off the ground that is to make sure the pump is aligned then by hand screw bolts back on evenly to ensure alignment... so wish me luck
Good luck
I thought most tensioners had a 1/2 inch hole that allowed you to put a breaker bar on there?
Sounds like someone figured out a way to make it harder then it needs to be
Good point, OP might not realize there is a 3/8” square cut out for a ratchet drive to fit in on tensioner.  But very tight space to work in. I use a pipe extension on small ratchet. Need some of the plastic removed to even swing a tool.  Pulleys are almost right against cross member on transverse mount engines, as you know.
I replaced with a RockA Gates when bearing went, then belt squeeling.
