rossco Posted August 14, 2018 Report Share Posted August 14, 2018 Hi there, I'm new to the forum so firstly hello to everyone :D I have a Dodge Journey in my hands at the moment I'm having trouble with and I'm hoping I can find some suggestions here... The vehicle is a journey 2.0 crd 2008 automatic, the problem is when the gas is pushed the engine rpm does not increase but it does run a bit rough and stutters when you do. I have so far run diagnostics with a decent machine but only found transmission codes which seem to be old, there were no engine codes at all. So my first action was to replace the gas pedal/apps with a known to work used one but this has made no difference it's reacts the same when pushing the gas. I have now removed the anti shudder valve or electronic throttle body if you like and cleaned it out but it appears to move freely and smoothly. Again no warning lights on and I'm pretty sure no brake lights. Any help suggestions much appreciated. rossco Quote Link to comment Share on other sites More sharing options...
