Jefferson Moreira Posted August 17, 2018 Report Share Posted August 17, 2018 A few months ago maintenance was done on the engine of my Journey 2.7 and again I had an engine problem that overheated and damaged. It was heating only when in high rotation on the road, inside the city nothing happened. They could help me figure out the problem, the water pump had already been replaced. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 17, 2018 Report Share Posted August 17, 2018 Moved to the correct section. You state "They could help me figure out the problem", did they? Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 19, 2018 Report Share Posted August 19, 2018 This just seems like a statement of a recent event...unless I am missing the question somewhere in there(???). Quote Link to comment Share on other sites More sharing options...
rossco Posted August 19, 2018 Report Share Posted August 19, 2018 (edited) Check your radiator has good flow and also check the thermostat isn't sticking. Any radiator that's even partially blocked can kill engines. Could explain why your cooling fan has no issue controlling the system temperature in the city but fails on the open road as higher revs = more heat, failure to expel heat = overheat. Also check your coolant is rich enough and not had water added too many times. Rossco Edited August 19, 2018 by rossco 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Jefferson Moreira Posted August 20, 2018 Author Report Share Posted August 20, 2018 On 8/19/2018 at 10:55 AM, rossco said: Check your radiator has good flow and also check the thermostat isn't sticking. Any radiator that's even partially blocked can kill engines. Could explain why your cooling fan has no issue controlling the system temperature in the city but fails on the open road as higher revs = more heat, failure to expel heat = overheat. Also check your coolant is rich enough and not had water added too many times. Rossco Expand I already tested the radiator. And the cooalant fluid is normal Quote Link to comment Share on other sites More sharing options...
Jefferson Moreira Posted August 20, 2018 Author Report Share Posted August 20, 2018 Someone has the height of the original head. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted August 21, 2018 Report Share Posted August 21, 2018 On 8/20/2018 at 11:11 PM, Jefferson Moreira said: Someone has the height of the original head. Expand Sorry, WHAT??? larryl 1 Quote Link to comment Share on other sites More sharing options...
Jefferson Moreira Posted August 21, 2018 Author Report Share Posted August 21, 2018 On 8/21/2018 at 3:05 AM, OhareFred said: Sorry, WHAT??? Expand Height of valve control block? Quote Link to comment Share on other sites More sharing options...
Jefferson Moreira Posted August 21, 2018 Author Report Share Posted August 21, 2018 If anyone has the repair maintenance manual, could you send it? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 21, 2018 Report Share Posted August 21, 2018 On 8/21/2018 at 3:21 PM, Jefferson Moreira said: If anyone has the repair maintenance manual, could you send it? Expand You can buy them off ebay.. OhareFred 1 Quote Link to comment Share on other sites More sharing options...
rossco Posted August 21, 2018 Report Share Posted August 21, 2018 You don't say whether you've had the thermostat changed or not? I mentioned this in my first post. They can get "sticky" and appear to work ok at times. Removing the thermostat to discount it is a regularly used diagnostic method. Also the easy way checking rad in and out hose temps can indicate there is no flow due to thermostat being closed. Rossco jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Jefferson Moreira Posted August 23, 2018 Author Report Share Posted August 23, 2018 On 8/21/2018 at 7:07 PM, rossco said: Você não diz se mudou o termostato ou não? Eu mencionei isso no meu primeiro post. Eles podem ficar "pegajosos" e parecem funcionar bem às vezes. Remover o termostato para descontá-lo é um método de diagnóstico usado regularmente. Além disso, a maneira mais fácil de verificar a entrada e saída de mangueira pode indicar que não há fluxo devido ao fechamento do termostato. Rossco Expand The thermostat has been removed. Quote Link to comment Share on other sites More sharing options...
Hankster Posted August 23, 2018 Report Share Posted August 23, 2018 Time to have a professional mechanic diagnose this, probably better than just throwing parts at it. Hank jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 23, 2018 Report Share Posted August 23, 2018 On 8/23/2018 at 4:05 PM, Hankster said: Time to have a professional mechanic diagnose this, probably better than just throwing parts at it. Hank Expand Agree Quote Link to comment Share on other sites More sharing options...
rossco Posted August 23, 2018 Report Share Posted August 23, 2018 Would also help I find you would tell us everything that you have had done already so we can stop wasting time making suggestions you've already tried. At this point I would be checking the radiator flow again as something's not right. Just because water comes out the bottom does not mean "it's fine". rossco jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Hankster Posted August 23, 2018 Report Share Posted August 23, 2018 Headgasket, jumped timing, lots of possibilities Hank Quote Link to comment Share on other sites More sharing options...
Armando G Posted August 28, 2018 Report Share Posted August 28, 2018 I won't jump in and try to pull any teeth. You guys can play 100 questions and maybe come up with the answer. OhareFred and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 28, 2018 Report Share Posted August 28, 2018 OhareFred, Armando G and rossco 3 Quote Link to comment Share on other sites More sharing options...
