davidmack4044 Posted September 9, 2018 Report Share Posted September 9, 2018 Need to replace seat trim on 2013 Dodge Journey. Any advice on how to remove seat adjustment lever? Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 9, 2018 Report Share Posted September 9, 2018 i assume you are replacing it due to the plastic tabs that holds it on have broken as mine did on my 2011 and also 2014 journey i didnt replace i just held it in place where it is suppose to be and drilled a small hole thur the side and then added a small black screw to hold it then moved back about 2 inches and then repeated the process never had any more problems with it. so i didnt have to fool with the seat adj or thew seat belt brackets. this is a very common problem with journeys jkeaton 1 Quote Link to comment Share on other sites More sharing options...
