Castro23 Posted September 9, 2018 Report Share Posted September 9, 2018 (edited) I have a 2015 dodge journey se, within the last 4 days have had to repair the radiator hose because it was leaking, then after we noticed it was running hotter then it should so we decided to take it to the dealer, after checking it they said there was a leak in the heater hose, it was gonna cost $521 to fix it so my dad was able to fix that part himself tobsave on cost but it's still running hot not as bad as before but still going past the half way mark. So next we have changed out the temp sensor it does fine if you are driving 60 or less but when you reach about 65-70 mph its begins to heat up and temp reaches 239° oil- 206° and trans temp is 125°. Once you begin to drop speed though the temp starts to come down, our next thought is the thermostat, but would anyone else have any suggestion on what it could be? Or does anyone know what the normal running temp should be? Edited September 9, 2018 by Castro23 Link to comment Share on other sites More sharing options...
larryl Posted September 9, 2018 Report Share Posted September 9, 2018 Do you have enough coolant in the system? Link to comment Share on other sites More sharing options...
Castro23 Posted September 9, 2018 Author Report Share Posted September 9, 2018 Yes, we bought some and added coolant when we changed out the heater hose. Link to comment Share on other sites More sharing options...
2late4u Posted September 9, 2018 Report Share Posted September 9, 2018 (edited) i would have changed the thermostat out the same time i did the hose. what engine do you have? Edited September 9, 2018 by 2late4u Link to comment Share on other sites More sharing options...
Castro23 Posted September 10, 2018 Author Report Share Posted September 10, 2018 (edited) Yes we should have that was exactly the issue the thermostat was not opening, switched it out runs perfect now, have a 2.4L 4 cylinder engine..now we know but hopefully won't have this issue for a long time from now. Thanks! Edited September 10, 2018 by Castro23 OhareFred and 2late4u 1 1 Link to comment Share on other sites More sharing options...
2late4u Posted September 10, 2018 Report Share Posted September 10, 2018 great that you respond with the fix will help others maybe...take care Armando G 1 Link to comment Share on other sites More sharing options...
