nnngn_zero Posted September 11, 2018 Report Share Posted September 11, 2018 Hello, The ABS light comes and goes on our 2015 Journey 2wd. Occasionally the red brake light is on as well. Checked brake fluid which is full. Not the parking brake either. Had a friend Hook an OBD scanner (not sure which kind) All 4 speed sensors were reading but it indicated to check the front right tone ring. Also failed speed sensor calibration check. My research indicates that it is part of the bearing hub. Can someone Please confirm? Or have any thoughts? Thanks for the information. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 11, 2018 Report Share Posted September 11, 2018 Sounds plausible. Quote Link to comment Share on other sites More sharing options...
nnngn_zero Posted October 21, 2018 Author Report Share Posted October 21, 2018 Further updates to this issue. The ABS and ESC come on faithfully every time the car is started. A minute or so after moving the car, the brake light comes on as well. I now have a Creader so I can check codes and ABS stream, and now the front two wheel speed sensors do not read. Codes that come back each time after they are cleared after each trip are C0031-62 and C0034-62 both are for FL/FR wheel sensors signal compare failure. The wheel speed calibration still shows as failed and now the setting that reads vehicle speed in the ABS module stays at zero... not sure if that is related to the wheel speed sensors, however there are no DTC set for vehicle speed sensor. Quote Link to comment Share on other sites More sharing options...
2late4u Posted October 22, 2018 Report Share Posted October 22, 2018 have no idea to me it would be dealer time.good luck Quote Link to comment Share on other sites More sharing options...
