2016RT Posted September 17, 2018 Report Share Posted September 17, 2018 OK, So I get in the 2nd row seat and I start to play with the climate control knobs. No real reason, I never sit back there so I figured I would check things out. Upon turning the knobs I find that the entire assembly, headliner included are not anchored to the roof. It drops down a good 2", maybe a tad more. 1st question; Is this normal, or am I simply to type-A of a personality to think it should not be this way? 2nd; In my quest to understand why this part is not attached as I think it should be I attempt to remove the climate control assembly. What is the intended method of removal? I tugged, squeezed, rotated, used plastic wedges to compress invisible clips, no joy. What gives? I took a breath, and exited the vehicle before I took the saw zaw to it. Seeing how I have yet to find a functional service manual for this vehicle, I would be grateful if one of you learned men or women can shed some light on this predicament. Did I mention this is my wife's vehicle!? What possessed me to even get in it? No matter, the damage is done. Thanks, Land Locked In AZ. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 18, 2018 Report Share Posted September 18, 2018 Yes. It’s normal. There was a thread in here awhile back discussing this. Our 2013 is the same way. Held in place by reverse gravity or something like that. It will outlast the vehicle unless you start pulling and tugging on it to find out the breaking point. WinstonD and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
2016RT Posted September 18, 2018 Author Report Share Posted September 18, 2018 Ok, I guess I will learn to live with it. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
