Suspension noise
Purchased our Dodge Journey new in 2014.  Can't begin to tell you how many problems we've had with it.  One of the issues that is still on going and our local dealership refuses to address anymore, is the extremely loud noise under the car when going over bumps, breaking, turning, change in pavement, etc.  It sounds like squeaky spring mattress!  Car continues to pull to the right even after alignment.  Has anyone had this problem with their Dodge Journey?  If so, what was done to repair it?  So disappointed in Dodge and the dealerships for telling us it's "operating by design."  If that were the case, it would've done this from day 1!
Possibly exhaust heat shielding?
You could check the anti roll bar drop links.
If not them then check the lower arm ball joints, track rod end ball joints, arm and roll bar bushes and lastly strut top mounts.
Maybe even engine or subframe mounts.
Get under it and have a poke around.
