and1 Posted December 30, 2009 Report Share Posted December 30, 2009 Help Please. Does anyone know if the 3.5L High Output SXT Model has an Engine oil cooler standard our how do I find if it has one? My Journey did not come with the Trailer tow package so what are all the things that will have to be added in order to tow a 3000lb ski boat. Quote Link to comment Share on other sites More sharing options...
crunkfrunk Posted December 30, 2009 Report Share Posted December 30, 2009 You will see 2 smaller lines running into one end of the radiator going to underneath the engine Not sure what else you would need Quote Link to comment Share on other sites More sharing options...
and1 Posted December 30, 2009 Author Report Share Posted December 30, 2009 Thanks for the info i will look for the lines.Help Please. Does anyone know if the 3.5L High Output SXT Model has an Engine oil cooler standard our how do I find if it has one? My Journey did not come with the Trailer tow package so what are all the things that will have to be added in order to tow a 3000lb ski boat. Quote Link to comment Share on other sites More sharing options...
BUGS Posted January 14, 2010 Report Share Posted January 14, 2010 If you are not an aggressive driver with a trailer load all you may need to do is change the engine oil a bit more often - like every 4-6 K instead of 10K. The oil temp will tell you if you need a cooler, most times not. I tow 3800 lbs with no appreciable engine temperature rise. The oil is already cooled in lower portion of the radiator and the transmission fluid is cooled by the condensor for the A/C (so my mechanic says). I also found out it will cost approx. $500.00 to install additional oil cooler using Dodge parts. Quote Link to comment Share on other sites More sharing options...
09DWBJOUNEY Posted May 20, 2010 Report Share Posted May 20, 2010 I just had my mechanic install the factory oil cooler. He charged me for two hours and I was happy. If you purchased the attached list you would have a few extra parts but I am not sure what was extra. Enjoy! DWB http://dodgeparts.mopar.com/dodge/journey-parts.html Select engine 3.5l High Output then select engine oil cooler [COOLER, Engine Oil] COOLER, Engine Oil Part Description Qty Unit Price Net Price COOLER, Engine Oil 3.5L High Output V6 24V MPI Engine $92.10 $92.10 [Add COOLER, Engine Oil to cart] [ADAPTER, Oil Filter] ADAPTER, Oil Filter Part Description Qty Unit Price Net Price ADAPTER, Oil Filter 3.5L High Output V6 24V MPI Engine $110.00 $110.00 [Add ADAPTER, Oil Filter to cart] [CONNECTOR, Oil Filter] CONNECTOR, Oil Filter Part Description Qty Unit Price Net Price CONNECTOR, Oil Filter M22X1.50 3.5L High Output V6 24V MPI Engine $6.30 $6.30 [Add CONNECTOR, Oil Filter M22X1.50 to cart] [GASKET, Oil Filter Adapter] GASKET, Oil Filter Adapter Part Description Qty Unit Price Net Price GASKET, Oil Filter Adapter 3.5L High Output V6 24V MPI Engine $11.45 $11.45 [Add GASKET, Oil Filter Adapter to cart] [bOLT AND WASHER, Hex Head] BOLT AND WASHER, Hex Head Part Description Qty Unit Price Net Price BOLT AND WASHER, Hex Head M6X1.00.X25.00 Mounting, Oil Filter Adapter To Oil Pan 3.5L High Output V6 24V MPI Engine $3.65 $3.65 [Add BOLT AND WASHER, Hex Head M6X1.00.X25.00 to cart] [HOSE, Oil Cooler Inlet] HOSE, Oil Cooler Inlet Part Description Qty Unit Price Net Price HOSE, Oil Cooler Inlet 3.5L High Output V6 24V MPI Engine $19.45 $19.45 [Add HOSE, Oil Cooler Inlet to cart] [HOSE, Oil Cooler Outlet] HOSE, Oil Cooler Outlet Part Description Qty Unit Price Net Price HOSE, Oil Cooler Outlet 3.5L High Output V6 24V MPI Engine $12.35 $12.35 [Add HOSE, Oil Cooler Outlet to cart] [FITTING, Engine Oil Cooler] FITTING, Engine Oil Cooler Part Description Qty Unit Price Net Price FITTING, Engine Oil Cooler 3.5L High Output V6 24V MPI Engine $20.50 $20.50 [Add FITTING, Engine Oil Cooler to cart] [ Quote Link to comment Share on other sites More sharing options...
warbird24 Posted May 20, 2010 Report Share Posted May 20, 2010 When we ordered our Journey a week ago I made sure the box for the Trailer Prep was "X" out because I wanted to have the extra insurance of properly cooled oil for the long term benefit of the vehicle. My wife and I keep our vehicles a long time (10 plus years on average). For the price of this package, I feel it is well worth it. Quote Link to comment Share on other sites More sharing options...
Cableguy Posted October 17, 2011 Report Share Posted October 17, 2011 I purchased my 2010 Journey SXT V6 with the tow prep group and it states in the specs that it came with an oil cooler. Now I have recently done my own oil change now with synthetic oil and it states the engine takes 6 quarts or 5.7 litres. If your Journey came with the tow prep group option then you should have an oil cooler. Double check with your dealer to be safe! Quote Link to comment Share on other sites More sharing options...
