Frustrated mom Posted October 14, 2018 Report Share Posted October 14, 2018 Hi i have a 2012 Dodge Journey, And every couple of days when I go to start it(push Start) it won’t start and it makes this clicking sound all the lights work and radio but car won’t kick over . And this red volt shows on the dash and the check engin light come on to and I’m left stranded after a couple hours it starts back up ...... please help Quote Link to comment Share on other sites More sharing options...
2late4u Posted October 14, 2018 Report Share Posted October 14, 2018 (edited) first off is it the org battery? even if its been changed have a load test done on it to see if it is still good. also check all your connections on the battery, yes it would be a pain to have to actually check the battery under the wheel compartment but the connectors could be corroded or loose. check all other connections as well get rid of the easy and cheap fixes first before diving into bigger and more expensive options... Edited October 14, 2018 by 2late4u OhareFred and jkeaton 1 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted October 14, 2018 Report Share Posted October 14, 2018 that is your electronic throttle control symbol if it is on solid all the time you have some time to get it checked, if it is flashing that means you need to get it looked at right away jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 14, 2018 Report Share Posted October 14, 2018 Agreeed. Start with getting the battery checked. Quote Link to comment Share on other sites More sharing options...
