Dodge JourneyCrooroads 2016 back up camera
When I remove the 4 screws holding the back up assist camera and license plate light assembly there is something in the middle at the camera area that is still attached and keeping me from removing the assembly. Any ideas what this could be and how to undo what ever it may be?
I disassembled the interior hatch trim breaking one clip in the process but found the stud and nut you mentioned. unplugged and removed the camera. Reinstalled the interior trim with the missing broken clip; I think it will be alright as is. Now to find a new camera.  Thanx  bramfrank
When I put the car into reverse the back up assist  camera displays the sentence on the top of the screen that reads “check all surrounding areas” and the rest of the viewing screen is nothing but static and red squiggly intermittent lines. The screen works fine for the radio and system functions so I believe the radio/monitor is functioning OK. Pulled the camera to check for damage ( housing, wires etc...). If it’s not to expensive I was going to put in a new one. Might be a fix or not. Any ideas?
  • 2 months later...
I have actually done nothing with this issue since I took out the camera. I have not had the camera tested yet.  Talk about procrastination. Starting to get use to not having it. But maybe this post will motivate me.
