Coopsrhere Posted October 31, 2018 Report Share Posted October 31, 2018 We have a 2010 journey, our power outlets that have blown a fuse. Can someone please tell me where the fuses are for them, I have searched YouTube, Google and I'm getting no help whatsoever! If its inside then where because we dont see a thing under the glove box! Starting to pull my hair out over this searching for weeks! Thank you Quote Link to comment Share on other sites More sharing options...
larryl Posted October 31, 2018 Report Share Posted October 31, 2018 (edited) your owners manual will tell you where the fuses and panel are located. there is one below the glove box on the firewall and one in the engine compartment on the drivers side that is marked its a black box Edited October 31, 2018 by larryl 2late4u and OhareFred 1 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 1, 2018 Report Share Posted November 1, 2018 Try searching your owners manual. Lol 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Coopsrhere Posted November 13, 2018 Author Report Share Posted November 13, 2018 I'm not that foolish guys, I did search my owners manual before I posted this but thanks for the input.......it doesn't say where it is! My husband and I have been searching under the glove box and there is no fuse box/panel there! Quote Link to comment Share on other sites More sharing options...
OhareFred Posted November 13, 2018 Report Share Posted November 13, 2018 I think my 09 fuse box on the inside is on the passenger side, below the glovebox, but on the side . So if you are looking from the seat, under the glovebox, on the right wall in front of the door. I’ll check when the car is here and post if I’m wrong. Coopsrhere 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted November 13, 2018 Report Share Posted November 13, 2018 ^^^ yes I think you have to pull the carpet back? Quote Link to comment Share on other sites More sharing options...
OhareFred Posted November 13, 2018 Report Share Posted November 13, 2018 I recall removing the plastic kick panel but not sure about the carpeting. Quote Link to comment Share on other sites More sharing options...
2late4u Posted November 14, 2018 Report Share Posted November 14, 2018 (edited) i just googled .........dodge journey inside fuse box location....... there is a video of it right below the glove box partially covered it looks like by carpet and or cardboard cover ............. Edited November 14, 2018 by 2late4u Coopsrhere 1 Quote Link to comment Share on other sites More sharing options...
Coopsrhere Posted November 16, 2018 Author Report Share Posted November 16, 2018 Thank you everyone, we will have a try at it again tomorrow once it stops snowing! Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 16, 2018 Report Share Posted November 16, 2018 Snow? Already? Quote Link to comment Share on other sites More sharing options...
Coopsrhere Posted November 16, 2018 Author Report Share Posted November 16, 2018 It's been snowing none stop since last night! We have looked under there and there doesn't seem to be a panel box anywhere! It's back breaking to look for this fuse box! We took the carpet out but still nothing! I'm going to go insane if we don't figure this out soon! :/ Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 17, 2018 Report Share Posted November 17, 2018 (edited) IIRC, its a very small box. Mostly covered by carpet and a pain to find. I had to lay upside down on the front seat with my head up under the dash to find it. Edited November 17, 2018 by jkeaton 2late4u and OhareFred 1 1 Quote Link to comment Share on other sites More sharing options...
2010JourneyGuy Posted March 14, 2020 Report Share Posted March 14, 2020 My 2010 Dodge Journey does not have an inside fuse box. You are not going crazy, all the fuses are in the engine compartment. They changed this in 2011 I believe to put it under glove compartment, but 2009 -2010 are this way. I just installed an aftermarket radio deck, and needed to run a red (ACC) wire to fuse box. Instead of running a wire through the fire wall, I pulled apart the center console and drink holder (there were 2 screws hiding underneath the drink holders which took me a long time to figure out - had to remove rubber insert to find them) and I spliced into the top charging port that works with the ignition. Hopefully this helps someone out there. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 14, 2020 Report Share Posted March 14, 2020 (edited) My 09 has one on the passenger side by the kick panel..... There is ALSO one under the hood. Got mine inJuly of 08 so no, they didn’t change anything, you just didn’t find it.? Edited March 14, 2020 by OhareFred jkeaton and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
D-baylor Posted May 31, 2020 Report Share Posted May 31, 2020 Ok so I've been trying to find this inside fuse panel. Nothing under the glove box. Just an amp to the right. Does it matter that it's an r/t? I've looked all around the area and nothing. My 6 disc changer won't load or eject. Anyone have a fix for this? Quote Link to comment Share on other sites More sharing options...
OhareFred Posted May 31, 2020 Report Share Posted May 31, 2020 I have an 09 RT. Passenger side, under the glovebox near the right kick panel. I don’t recall if it’s got a cover on it(I think it does) so it looks like a black box. Not sure what Amp your seeing, but I thought the amp was under the drivers seat, but I don’t have the premium sound system so it might be different.... Quote Link to comment Share on other sites More sharing options...
2010JourneyGuy Posted May 31, 2020 Report Share Posted May 31, 2020 If your user manual only shows one fuse box under hood, you do not have one inside the vehicle and all fuses are under the hood in engine compartment. If you see inside fuse box in the manual, then you have one inside. Quote Link to comment Share on other sites More sharing options...
Battlewes Posted May 18, 2024 Report Share Posted May 18, 2024 I've got a 2010 Dodge Journey basic vehicle four cylinder no power windows nothing took out the stereo if the like the head unit for a for their digital one as a it's a DVD player but since it don't have big screen it don't work and I'm replacing the stereo and I need this fixed anyway all my power outlets that are on all the time all the fuses are good but no power is getting to them and I was going to try to use that as my on always power supply don't know what the hell's wrong I'd appreciate any thing you could do. Quote Link to comment Share on other sites More sharing options...
