ABS light on
Hi All,
I have a Dodge Journey 2014 SE and the other day the ABS light came on and it's been intermittent. I bought a ABS scanner and I found the following codes:
C00311D   Left front wheel speed sensor circuit current out of range.
C003162   Left front wheel speed sensor signal compare failure.
After that, I replaced the sensor and erased the abs codes. I'm still getting the ABS light.
My questions to the Forum:
Is there a way to test the cable harness that goes from the sensor connector and back to the module?
When I removed the sensor I tried to find the tone ring but I couldn't see it thru the sensor hole, are they like that or my tone ring is gone?
If I have to replace the tone ring, which part is the one I need to buy? the wheel hub assembly or the axle ?
Thanks
