Headlights Dimming and Brightening
This has probably happened to a lot of people. It usually means your battery is getting low or your alternator is going out. But since there isn't much more info provided and we know nothing about the past maintenance of the car, it could be a number of things.
  On 12/1/2018 at 12:25 AM, 2late4u said:
wasn't there a recall or tsb on the headlights? check with your dealership about what is going on......
Expand
There is a TSB related to the concern you are describing on some Dodge Journeys:
"NUMBER: 08-097-17
GROUP: 08 - Electrical
DATE: September 28, 2017
SUBJECT: Flash: BCM Diagnostic and System Improvements
NOTE: This bulletin applies to vehicles within the following markets/countries: NAFTA and EMEA.
NOTE: This bulletin applies to vehicles built on or before August 28, 2017 (MDH 0828XX).
SYMPTOM/CONDITION: The customer may describe the headlamps flicker while operating at night. This condition may be more prevalent after the bulb(s) have been replaced with an aftermarket bulb."
Your dealership will be able to identify if this TSB applies to your vehicle or you can send us a PM with your VIN and I can check for you as well!
