Dodjour Posted November 19, 2018 Report Share Posted November 19, 2018 2010 dodge journey has no heat to rear at all. Front heat works good. Replaced rear heater core, both thermostats, and flushed the lined to ensure no blockage. I have verified im getting SOME coolant to the rear but the lines running to the back are not even getting hot so i think the flow is very very minimal. Its almost as if the front heater core is taking all the hot coolant away... any thoughts? Quote Link to comment Share on other sites More sharing options...
Travis robinson Posted June 15, 2020 Report Share Posted June 15, 2020 Im having same issue have you figured out what issue was Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 15, 2020 Report Share Posted June 15, 2020 as usual most few time posters never report back on what they found out to be their problem. OhareFred and Outside Dog 2 Quote Link to comment Share on other sites More sharing options...
aragorn0257 Posted January 21, 2022 Report Share Posted January 21, 2022 Just this evening I was having this problem with my wife's 2012 Journey and could not get anything but cold air from the roof vents in the rear no matter what I tried. Then I got the bright idea that it might be an air lock in the rear heater core, so I pulled the car into the driveway, leaving the rear wheels at the curb. This caused the front end of the car to be raised about 6 to 8 inches higher than level, after revving the engine to about 3 grand, lo and behold...Heat from the ceiling vents. Seems it was an air lock all along. Hope this helps someone else out there. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
