Rad fan not cycling correctly
Dodjour
Can anyone tell me the parameters for wich the electric cooling fans turns on/off?
it’s not causing overheating issues in the engine but it is causing A/C issues. At idle it will kick on but only for a few seconds then kick off and continue to do this regularly every few minutes. I want to know what is telling it to kick on and what values it used so i can determine the problem, or if there even is one.
