greasyfingers Posted December 20, 2018 Report Share Posted December 20, 2018 Have a 2012 journey that looses power and seems to not want to go. had the codes pulled P0128, p076a, p0128, p076a, p0441, p084a it seems to only do this after long (3-6) hour trips. doesn't do this all the time. I'm trying to narrow down what could be causing this, any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 20, 2018 Report Share Posted December 20, 2018 (edited) would have been as easy for you to google your problems.any ways here is what i found in about 10 seconds p084a and p076a is to do with your trans, Malfunction Indicator Light On Change in shift quality Vehicle starts off in 2nd or 3rd gear (limp in mode) sensor or solenoid valve in trans probably bad. and the other 2 is showing a low coolant temp problem ... good luck Edited December 20, 2018 by 2late4u larryl, jkeaton and OhareFred 3 Quote Link to comment Share on other sites More sharing options...
